Old 3/10/08, 6:56 PM
Steven C. Meyer Steven C. Meyer is offline
Please Note: Steven C. Meyer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Deckng question
How would you (or would you) report decking material that is buted togeather?
When I was in construction, I always allowed 1/4 inch between deck boards to allow for air flow and expansion in the wet season.
Inspected a new (replacement) deck where the decking material is snug. decking is of pressure treated variety if that makes a difference? This is the "wet" season here in the norhwest, so may shrink a bit when the weather drys out. Seller says deck installed during the summer dryer weather.
Thanks
Old 3/10/08, 7:09 PM
Roy D. Cooke, Sr's Avatar
Default Re: Deckng question
Thanks
Not my Job it is not a safety concern so look and move on if the deck has no other issues.
...Cookie
Old 3/10/08, 7:12 PM
Troy Farmer's Avatar
Troy Farmer Troy Farmer is offline
You are correct with the general 1/4 inch spacing, it is to allow water to pass through, to prevent rotting, and ponding
Troy Farmer
Presidential Inspections LLC
Chapter President Southern Idaho
PO Box 2144
Eagle, Idaho 83616
208-573-5300
http://www.presidentialinspection.com
http://info@presidentialinspection.com
"He who can, does. He who can’t, teaches"
"Where would we be without Teachers"
Old 3/10/08, 7:15 PM
I disagree it can be a safety concern if the water builds up. and then rot sets in.
And then what about WDO'S which that could be a conducive condition in WA, right Steve I did my WDO testing there, I would call it out if the condition was conducive.
Troy Farmer
PO Box 2144
Eagle, Idaho 83616
208-573-5300
Old 3/10/08, 7:17 PM
Michael Larson's Avatar
I used to build decks with 1/4" but the wood would shrink too much across the grain. I went to 1/8" and had much less trouble. Some of the wood is pretty wet when when you get it.
Never underestimate the difficulty of changing false beliefs by facts.[/I] - Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
Old 3/10/08, 7:21 PM
James F. McKee's Avatar
with pressure treated 5/4" that is wet I always butt it as tight as i can and presto a few months later a near perfect 1/4"gap, just like magic....this only works on wet pressure treated or green lumber...other types must be spaced.....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 3/10/08, 7:23 PM
I just learned this today check it out regarding your Green lumber.
http://www.cvswmd.org/resident_servi...enic_faqs.html
Troy Farmer
PO Box 2144
Eagle, Idaho 83616
208-573-5300
Old 3/10/08, 7:26 PM
James, I was just about to say the same thing.
I agree, with pressure treated lumber, installs should be as tight as possible.
Water content is up in the 30's and 40's in some lumber yards.
Marcel
Old 3/11/08, 12:32 AM
rwiley's Avatar
rwiley rwiley is offline
Send a message via Yahoo to rwiley
Ditto what James said, 1/4 now is over 1/2 in 3months if you'r talking about 5/4 PT
Got a letter from ASHI's President today. gromicko General Inspection Discussion 55 12/12/10 11:51 PM
Interesting Question? jmckenna1 Miscellaneous Discussion for Inspectors 9 11/25/07 1:13 PM
