I have a builder client who has a bad batch of engineered flooring which is bowing and cupping after installation on a concrete slab. The flooring has been tested for moisture and normal, the concrete has been tested for moisture and normal and the flooring company has continued to say there is noting wrong with the product. The installer is very professonal with years of installing this product with no other problems. The flooring is bowing and cupping before and after installation resulting in the joint pulling apart and an uneven floor. Any ideas on continued testing of the wood product and any good ideas on a testing lab that could do the test?
Thanks Russ |
| Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What is the moisture reading when you scan the top of the flooring and what brand name moisture meter are you using?
Every manufacturer I know requires a vapor barrier between the concrete and the floor. You should see the barrier when the trim along the wall is removed. Just because you do see a barrier, does not mean it is installed correctly. This publication is how they are general installed http://na.pergo.com/Images/how_to/In...ials_Guide.pdf . Mold is bad about growing on the underside of the floor planks when a barrier is not installed properly. I was sick in bed this weekend and I was watching a home improvement show and they actually was gluing the floor planks directly to the concrete. Some so called experts need to be slapped. Sad but true. Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Concrete slab. Was this a basement or slab on grade?
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Not that bad, there is a moisture product installed and this is an engineered wood floor with moisture level less than 10%. I'm thinking that since this is south Texas, the flooring is picking up moisture from the atmosphere.
is there enough room for expansion along the edges?
How long has the flooring been installed? How does the warranty read?
did the installer follow and acclimate the material prior to install?
what are the indoor temperature & humidity levels? i use http://www.wunderground.com/US/TX/Bulverde.html scroll down to History & Almanac and get all the daily info i may need for documentation... ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
usually the flooring materials are supposed to be left in the room for 24-48 hours before installing to give them acclimation time.
rachine safire is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you have any problem with your flooring, then your flooring company has to compensate it if their products are in the guarantee period. So you can claim on them or if there is no problem with the product, then your flooring may be absorbing moisture from the atmosphere.
____________________ natural stone tiles |
| History of Rubber Tiles | mcyr | Miscellaneous Discussion for Inspectors | 0 | 12/4/11 9:51 AM |
| Infrared Detects Defective Thermal Seals During Utah Building Inspection | bclark3 | Thermal Imaging, Infrared Cameras & Energy Audits | 3 | 2/2/11 3:45 PM |
