So what do you do differently on a Full Inspection vs a Yearly Maintenance Inspection ?
Discuss please Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
| Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
There should be no difference.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
I don't do them, but if I did, an annual maintenance inspection would not be redundant by reporting the model numbers/age of mechanical devices or describe the materials used for roofing, exterior siding, foundation, etc. each year.
An annual maintenance inspection would be limited to describe the condition of the particular systems and it would compare the present conditions to previous reports. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Thanks Gary and Jim, all good stuff, I would love to hear some other opinions. The reason I ask this is that I have been asked several times lately if I would do an annual maintenance/safety check up. So I am curious what that term really refers to. As Gary said I cant really see what the difference would be. By leaving something out in the inspection, I would think you are just doing a partial inspection and could omit the important defects (if any).
I feel as James says that you are (for the most part) reviewing a previous inspection, usually 1 year later, so you are addressing changes in conditions that have happened in the past year, both good and bad. Have the deficiencies from the original report been addressed? Are there new deficiencies? Are the major components aging correctly? And so on..
Eric W. Augustin A1 Certified Home Inspections If you can't explain it simply, you don't understand it well enough. Albert Einstein
Hummm, kind of like what I was thinking of http://www.nachi.org/forum/f13/aging...-emblem-59973/
| Mold Inspectors in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 15 | 1/3/12 1:14 PM |
| BC is acting on the new bill | jkoong | Canadian Inspectors | 21 | 2/19/08 7:38 AM |
