I take alot of pictures during an inspection, does anyone have an idea what camera would be the best for the battery lasting the duration of an inspection? I take about 100 to 130 pictures in a few hours time? I have tried a few smaller cameras and the newer ones that have AA bateries, but I have to change two or three times, and I lost a few pictures that way. If anyone has experienced this please let me know what you have come up with for a solution. Thanks in advance. Greg
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Hi Greg,
I use a Canon SX120 (new model is an SX130); I take 300 to 500 pictures per inspection and have no problem with one set of batteries. I use standard rechargeable batteries, I always have a spare set of batteries in my pocket and occasionally have to change them out during a job; more so if I have to use the flash because of dark interior conditions. Standard throw away batteries are good for no more than 100 to 150 pics so maybe going to rechargeable batteries will solve your problem. By the way I have never lost a picture changing batteries. Mark Raumikaitis, CMI, NH Lic #133 HomeCheck Professional Home Inspections LLC Derry, NH 603-432-3211 Inspecting New Hampshire and Southern Maine http://homecheckhomeinspections.com/ "Always think long term, do not be influenced by short term thinking or rewards."
Here's what I use. http://www.olympusamerica.com/cpg_se...p?product=1497
I take 300-500 pictures during a typical inspection. With any camera you use, the resolution is the single biggest culprit of your batteries life. Personally, I like to take my pics at no less than 5MP, usually 8MP. (Camera is a 14MP, and use it on ground to roof shot's when necessary). The high MP pics have saved my butt a time or two (zoom in quality). At 5MP, I get about 150 pic's from standard Duracell AA's. Many inspectors, and inspection report software companies, claim that 3MP is more than sufficient. Tried it, got about 225 pics from the Duracell's, but didn't like the low quality shot's. Try it and judge for yourself.
But, how many pictures do you take in an average inspection? If I remember correctly, you take very few in comparison.
I use the Olympus TG-610 I get about 250 - 300 pictures out of each battery.
David Hays All Points Home Inspections LLC Denver, CO 720-670-0366 allpointshomeinspect@yahoo.com www.allpointshomeinspections.org |
My camera charges through the USB port & gets charged daily. I'm using the original battery that came with the camera when I purchased over 2 years ago. This spring I will be buying another one, whether I need to or not.
I Use the same as Kevin and Jeff i carried a spare battery hardly use it but some days i do, 250 to 300 Pictures . battery life .
Been using 1.5 years no problems dropped in water dropped from the ladder . Before then i went through one every 4 months . always got jammed shutters with dirt. or crushed screen. Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
FWIW - I don't carry a "spare" battery. I rotate them evenly and use each one until it's dead before I change it out. Full-charge/discharge cycles helps to extend the life of rechargeable batteries. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
about 250 Pictures each Battery Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Do not take this the wrong way but why so many pictures? Are you and inspector or a photographer?
Pictures should only be taken when necessary omit the clutter. |
I use a Pentax waterproof camera, take as many pics as needed, sometimes a lot, sometimes only a few. I use my camera as basically a recorder of the inspection. This allows me to step through many steps quickly because I have documentation in the form of a photo. I generally do not use all the photos I take but still have them on hand for later use if necessary. It takes no more money to take 200 photos as it does 50. I DO NOT take photos of loose doorknobs. Having many photos on file has saved my buttocks as well as my previous customers a lot of aggravation later. Had a customer who had their compressor unit replaced under warranty, the contractor put a 2 ton in place of a 2.5 ton, swore it as only a 2 ton. The customer had either lost or deleted their photos in the email album I sent them (this was less than a year later) called me to see if I had anything other than the report that indicated it was in fact 2.5 ton. I had the photo of the outdoor unit data plate. The contractor had to admit it was the larger unit and they got a new replacement and an apology. Happy customer
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
Keep in mind also, the type of homes I inspect VS what many others inspect on a daily basis. My 'typical' home inspection is over 50 years old, often over 100 years old. Mostly basements and usually full attics, or walkup attics. Frequent "hobby farms" (home with multiple out-buildings on 5 to 20 acres) where the farmhouse has been added on 2-3-4 times over the last 120 years. My inspections are unique when compared to many other areas of the country. Slab-on-grade homes? I see one maybe every year or two. They just don't exist around here. In comparison, the last one I did, I think I took about 120 pic's. It's no wonder the guys in California & Florida, (for example), do an inspection in 1-1/2 hours and can get away charging $199. Gravy work!!! Note: I should state that my reports contain whatever pics are needed, but usually around 50-60 average. Occasionally I have one in the 100-120 range, but that is rare. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Like Jeff I haven't taken notes in several years.
200- 300 pics per inspection. My camera is my notepad. I use hand signals in the photos to avoid confusion. Only 30 - 50 go in the report. I have 2 cameras, 5 Mpixel cannon with 12x optical zoom and cheap kodak 6 m pixel for most shots. Both take AA batteries and I carry extra non rechargeables so I always have power. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
| FLUKE Announces New Cameras & Price War Reduction | jmckenna1 | Thermal Imaging, Infrared Cameras & Energy Audits | 90 | 5/20/11 7:59 PM |
| NACHI School gives away FREE Digital Cameras! | trausch | Inspection Education & Training | 1 | 6/21/07 3:48 PM |
| Digital Cameras | wmcshan | Inspection Hardware, Software & Publications | 4 | 2/20/06 5:34 PM |
