Old 7/14/10, 12:17 PM
George E. Russell George E. Russell is offline
Default Do you floks say anything about rotted Expansion Joints?
Do you folks call out rotted and or missing expansion joints in driveways and sidewalks? To me they are the same thing as a large crack and should be sealed. What say you?
George Russell
George Russell Professional Inspections
Austin,Texas
TREC # 10215
512-296-9538
http://georgerussellprofessionalinspections.com/
http://www.facebook.com/austinhomeinspections
Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/14/10, 1:21 PM
Robert W. Jude's Avatar
Robert W. Jude Robert W. Jude is offline
Default Re: Do you floks say anything about rotted Expansion Joints?
Maintenance tip: sealing will extend useful life of sidewalks and driveway.
Old 7/14/10, 1:41 PM
Bob Elliott's Avatar
Yes I Observed as deferred maintenance
Old 7/14/10, 2:39 PM
ldapkus ldapkus is offline
I sealed my driveway expansion joints with this product yesterday. Self leveling rubber-silicone sealer. Good stuff!!
do-you-floks-say-anything-rotted-expansion-joints-img_0001.jpg   do-you-floks-say-anything-rotted-expansion-joints-img_0003.jpg
Old 7/14/10, 2:40 PM
Chuck Evans's Avatar
I don't comment on them unless they are big enough to fall into.
Not sure how a fresh board or joint filler would "extend the useful life" especially in our part of TX where freezing is unlikely. If the client asks about it, I'll advise a backer rod and concrete joint filler.
Edit: Like the stuff Linas used ^
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 7/14/10, 3:10 PM
Looks good.
Old 7/16/10, 8:17 AM
ok, maybe not in non freezing climates.
Old 7/19/10, 3:29 PM
dquigley's Avatar
dquigley dquigley is offline
Please Note: dquigley is a non-member guest and is in no way affiliated with InterNACHI or its members.
In Florida we typically have bituminus expansion material where concrete drive meets garage slab. The expansion material runs all the way from the top edge of the concrete down to the compacted earth. In other words it is a complete separation of the driveway from the garage slab. When this material wears, rots or is removed it leaves a big void. normally their is at least one gutter downspout in this area discharging lots of water onto or around the edges of the drive. Needless to say, the undermining of soil beneth the driveway is a common occurance - leading to driveway failure when vehicles drive over the unsupported areas. no freezing around here, but a major problem none the less.
Roof Deck Seams Visible - What's Wrong? psullivan Roofing Inspections 35 11/30/10 1:22 AM
Water heater expansion tank jfrederick Plumbing Inspections 3 11/17/08 3:35 PM
Question on slab cracks. mnahrgang Structural Inspections 8 4/29/08 3:52 PM
Expansion/ contraction joints jlybolt Structural Inspections 13 5/31/07 6:03 PM
Concrete Expansion Joints tsmith5 Exterior Inspections 10 1/20/07 5:56 PM
