Old 10/3/06, 1:11 PM
William Warner's Avatar
William Warner William Warner is offline
Default Do you measure water temperature???
Do you measure water temperatures?
If not, here's a reason to start from the Home Safety Council:
Leah's Story
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 10/3/06, 1:29 PM
Roy D. Cooke, Sr's Avatar
Default Re: Do you measure water temperature???
Leah's Story
Always test and 90% of the time it is too hot and I write it up as a saftey hazard needs immediate repair to 120 F .
I expect most take my advice on this .
Roy Cooke RHI. CMI.CHI.
Old 10/3/06, 1:33 PM
Michael R. Boyett's Avatar
I test and write it up as well if need be.
Old 10/3/06, 2:49 PM
dgagneur's Avatar
dgagneur dgagneur is offline
Please Note: dgagneur is a non-member guest and is in no way affiliated with InterNACHI or its members.
What a heart breaking story. This is the kind of article I will include in my binder that I bring to inspections to let clients/realtor look thru to pass the time. It certainly reinforces the need to keep water temp. at a safe level.
Old 10/3/06, 2:55 PM
Doug Edwards,  CMI's Avatar
Yes, for all the same reasons.
Old 10/3/06, 3:01 PM
I was recently reprimanded by a homeowner and realtor for calling out a water heater with a water temperature in the 130 degree Fahrenheit range. They chose to call me "nit-picky" for calling attention to what they believed to be an unimportant issue. I will continue to call out water heaters with water temperatures of 121 degrees Fahrenheit and higher regardless of who may be living there.
Old 10/3/06, 3:34 PM
David P. Valley's Avatar
Always.
Every report that goes out will have the domestic water temperature written up in the water heater section.
And don't forget about those old two-handled tub faucets without the anti-scald devices. Write em' up.
Old 10/3/06, 5:04 PM
pdacey's Avatar
pdacey pdacey is offline
Please Note: pdacey is a non-member guest and is in no way affiliated with InterNACHI or its members.
I always do and note the temp. in the report even if it is at an acceptable level. That way the client knows where the water heater is set going into the house.
Old 10/3/06, 7:19 PM
Yes. When over 125 I write it up for correction. (that is what the manufacturers stickers on the water heaters say )
Old 10/3/06, 7:41 PM
Brian E. Kelly's Avatar
No I do not measure hot water temp, but if I see the older two handled faucets in bathtubs or showers I reccomend an update with a thermostatic mixing valve, much safer.
There are some who think that the water heater temp should be above 120 F to prevent legionaires.
Never leave a child alone while drawing water in a bathtub or bathing.
Old 10/3/06, 9:03 PM
Steven E. Wiegner Steven E. Wiegner is offline
Send a message via AIM to swiegner
I Always Check Temp
Many Times It Does Not Acheive 100 Degrees
Water Heater Too Old
Needs Replacement
Old 10/4/06, 8:59 AM
Barry Adair's Avatar
CPSC Scald this goes in reports
Watts Scald this is info you can order free
Legionella is cover on page 3 http://www.watts.com/pdf/pg-mxv.pdf
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/4/06, 9:22 AM
Originally Posted by swiegner
I Always Check Temp
Needs Replacement
How can you tell that the water heater needs replacement by the temperature.
I set mine to keep the water at 108 degrees . I could have just as easy set it to 100 degrees or less.
I have seen 30± year old tanks doing just fine thank you.
Roy Cooke
Old 10/6/06, 8:05 PM
psiposs psiposs is offline
Send a message via Yahoo to psiposs
Where do you like to measure? Kitchen sink? Assumed farthest spout from the water heater?
And with what? IR meter?
Peter Siposs
Absolute Home Inspections
Home, Mold, IAQ, Radon, & Lead Based Paint
Liberty Lake, WA
Serving Eastern WA & Northern ID
Nachi# 05100181
peter@absolute-home-inspections.com
Old 10/6/06, 8:47 PM
I Guess you could say I have the cheapest meter in the World to test the Water Temperature.
My aged and calused hand. If it is too hot for my thick skin, most probably and likely, it is to hot for all the office workers. ha. ha.
Marcel
</IMG></IMG></IMG>
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 10 1/11/06 10:53 PM
