Old 10/12/09, 2:45 PM
Sean Fogarty's Avatar
Default Do you remove the dishwasher bottom cover?
During an inspection today, I started the dishwasher at the beginning. It was not till the end of the inspection and the dishwasher cycle, the customer spots a small stream of water running out in the grout line. Of course I was mad at myself for him finding it and not me, but it was just luck the water even ran out. After removing the cover I noticed quite a bit of water under the washer, and the best part was the wire splice sitting in the puddle. I know it is not sop or common practice to remove covers, but after today I think I will on every one. I was just lucky enough that it showed itself and someon saw it. It the water had never ran out I would missed it compleatly! Does anyone remove all covers?
Sean Fogarty
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
www.homeinspectionknoxville.com
Find an InterNACHI certified Oregon Home Inspector (and anywhere else in North America)
Old 10/12/09, 2:51 PM
Bob Elliott's Avatar
Default Re: Do you remove the dishwasher bottom cover?
I bet most do not ,but I am going to start thinking about it.
It would be good practice.
Old 10/12/09, 3:43 PM
John Shishilla's Avatar
John Shishilla John Shishilla is online now
I will not, I have installed many and you never know what may happen. Some of those covers have sound proofing and seals.
John Shishilla
State of Florida Licensed Home Inspector #21
Residential Contractor
Accredited Claims Adjuster (ACA)
Mold Assessor MRSA 1544
President of Fl Home & Insurance Inspectors Chptr
VP of Nachi Managment
Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas.
Honor Construction Inspection Service
www.honorconstruction.com
"Because details matter"
321-327-2950
Old 10/12/09, 3:57 PM
What???????????????
I installed them everyday for 6 years and have no idea what you are talking about.
Old 10/12/09, 4:19 PM
John, You lost me too. I am talking about the metal cover plate on the bottom. I have put in several dishwashers myself, and this is the first time I have ever seen a 2 year old washer leaking around the pump. By the looks of things it was leaking from the get go.
Sean Fogarty
865-256-5397
Old 10/12/09, 4:28 PM
Vince Santos's Avatar
Vince Santos Vince Santos is offline
I always cycle the dishwasher and note if it leaks. I don't take the cover off to look for a leak.
Vince Santos
StepByStep Home Services LC
(734) 748-9584
Providing Home Inspection Services to Southeast Michigan
facebook
ITA Trained and Certified
Old 10/12/09, 5:31 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is online now
I do take the covers off and am amazed how many leaks I find. Most are small but you know they will get worse. The only time I don't take them off is when there is enough of a gap between the cover and toe-kick to see underneath.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 10/12/09, 5:32 PM
Perhaps this makes a good excuse to buy a see snake.
Old 10/12/09, 5:36 PM
Not a bad idea because I HATE putting those covers back on. Most are two piece and a pain to get lined up.
Robert Newland
Tyrone, GA 30290
NACHI05101290
HomeGauge eServices
Old 10/12/09, 5:40 PM
True ,plus you need to be careful as I cut my hand up a few times when the electric was loose and not in the box where it should be.
Shock and awe became shock and bleed.
Old 10/12/09, 6:46 PM
I have been seeing the Low Noise units with a foam backer on the two part kick plate and a rubber seal to the floor and cabinets. Putting the seal in is a pain.
John Shishilla
321-327-2950
Old 10/12/09, 7:46 PM
Foam backer is common but I do not recall the rubber seal.
Old 10/12/09, 7:47 PM
Joshua L. Frederick Joshua L. Frederick is offline
Not any worse than an electrical panel cover, because we all know how the screws always line up so well
Old 10/12/09, 8:28 PM
Kevin M. Leonard's Avatar
Kevin M. Leonard Kevin M. Leonard is offline
Ditto. I will attempt to look under or around the sides if possible.
Kevin M. Leonard
The Ohio Home Inspections Company
513-895-7700
937-283-5118
Old 10/13/09, 11:38 AM
Frank M. Carrio, CMI's Avatar
Frank M. Carrio, CMI Frank M. Carrio, CMI is offline
ESOP Committee Member
Thumbs up Re: Do you remove the dishwasher bottom cover?
Sean,
I would say that you were very lucky on this inspection and that you "dodged the bullet". I have been in this industry since 1972 and some other things that I have found are;
1. Small leaks like you found.
2. Major leaks, and I mean MAJOR!
{This happens a lot on homes that have been vacant/closed/and or winterized for some time}
3. On more than one occasion the water line was disconnected!
{One job with brand-new hardwood floors was extremely exciting and I was lucky because the Real Estate agent was the one who ran the dishwasher and the water was just pouring all over the brand-new hardwood floors! It turned out to be $15,000 worth of damage to the floors!}
NOTE: If you see a BRAND NEW dishwasher {especially in an older home that was vacant} DO NOT assume that it is connected!
4. I have found "live wires" that were actually in the water.
Things I have found inside the dishwasher ...... after it was turned on by the Real Estate agent!
1. All of the paperwork/instruction manuals {they were soaking wet}
2. "Important Papers for the house"
3. Clothes.
4. Shoes.
5. Homework.
6. Baked Cookies on the top rack.
7. Leftover "birthday cake" that the homeowner wanted to make sure no one ate during the inspection.
8. A small box with all of the hidden "family jewels".
99% of the time I tell the real estate agent that it is a violation of my SOP to turn on the dishwasher and they have no problem turning it on. Most of them will even remove the kick plate.
So bottom line is..... I strongly advise you NOT to turn on the dishwasher but if you have to ..... be sure to check the inside of the dishwasher before you turn it on and be sure that the kick plate is removed so that you can see underneath the machine!
Good luck!
Signed, Frank Carrio, CMI
Certified Master Inspector & Consultant
Certified, WDI Inspector
Founder & Current President, New Hampshire State Chapter NACHI
NACHI, State Representative for Legislative Affairs
Retired: ICC Certified Member
Retired: Code Compliance Inspector.
Retired: ASTM Committee Member
New Hampshire License #0096
Would you remove this cover? jpope Electrical Inspections 46 5/17/09 3:38 PM
Electric Panel dmozzillo Electrical Inspections 26 1/26/09 2:18 PM
It's not necassary to remove Electrical Panel Cover. dvalley Electrical Inspections 13 7/3/07 4:22 PM
Check out Roy's NACHI plate cover, Bottom PIC. gromicko Canadian Inspectors 7 10/18/06 3:54 PM
Exploding Dishwasher mbledsoe Plumbing Inspections 8 2/28/06 8:13 AM
