I have noticed in my area most water haters and furnaces are gas and use Bvent. It also appears (driving around looking) most use the 3 rule, if it's 3 ft above roof it's o.k. Also how long of run can you have, another house I looked at only the water heater was on this approx 15' straight up then 14' of 30degrees then 6' up thru roof. I was curious about draft on this.
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
No. It's an exhaust vent, not a chimney.
I don't have the exact requirements in front of me, but generally it's 12" minimum projection above the roofline. Also, the vent should be extended above any window or vertical wall within 8' of the vent. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks guys
| Exterior stair rail....does the 4 inch rule apply ? | dnasser | Exterior Inspections | 4 | 2/22/10 2:02 PM |
| Washington HI licensing information from DOL | hmiller | Legislation, Licensing & Legal Issues for Inspectors | 182 | 10/3/09 1:14 AM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 10:24 AM |
