Lihe Huang is a non-member guest and is in no way affiliated with InterNACHI or its members.
I noticed that there are only hot wires going from the cutoff box to the AC unit outside. The cutoff box was grounded but no ground wire going to the AC unit. I am going to change the power whip with the ground wire and ground the AC unit. Is it possible that since the AC is on the ground so it does not need to be grounded? Does my adding the ground wire cause a problem? Most likely all the AC systems are connected like this in my development.
| Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
With out knowing your local code, the simple and safe answer is yes. the compressor should be grounded or bonded to or thru the service disconnect switch
Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
| Grounding electrodes at outbuildings | jfunderburk | Electrical Inspections | 18 | 12/13/10 7:18 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
