Old 7/8/10, 6:42 PM
Frank P. Macak Frank P. Macak is offline
Default Does anybody recognize this type of receptacle?
Does anybody know this type of receptacle - appears to be line voltage 240V with ground - circa 1920-1950. What type of appliance was it used for? Thanks guys
http://www.prime-inspect.com
PRIME INSPECTIONS Home Inspections in Delaware County NY, Otsego County NY, Chenango County NY, Chenango County NY, Broome County NY. I am a NY State Licensed Home Inspector lic.#16000041526
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/8/10, 7:04 PM
Stephen W. Stanczyk's Avatar
Default Re: Does anybody recognize this type of receptacle?
Antique tandem and parallel receptacle. circa 1910
http://home.netcom.com/~wa2ise/power/8plug.jpg
Stephen Stanczyk
Old 7/8/10, 7:06 PM
James H. Bushart's Avatar
Nurpolian is the brand name, according to Wiki.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Old 7/8/10, 7:09 PM
Michael Larson's Avatar
I don't think so guys.
Look at the original photo again.
The slots don't line up the same.
Never underestimate the difficulty of changing false beliefs by facts.[/I] - Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
Old 7/8/10, 7:44 PM
yes, the ports are offset - ??
Old 7/9/10, 6:50 PM
cjustason's Avatar
cjustason cjustason is offline
Wiki..... where you get all your facts?
Old 7/9/10, 6:53 PM
cjustason's Avatar
Are you in the U.S. of A?
Appears to be 240v? Did you check? What size and Type conductor if you can trace?
Old 7/10/10, 2:35 PM
Keith Runquist, CMI Keith Runquist, CMI is offline
Send a message via AIM to krunquist
May be a radio antenna plug.
Keith Runquist, CMI
Old 7/10/10, 2:44 PM
Jeffrey R. Jonas's Avatar
This is one of those topics where Mark Shunk always came through for us.
Old 7/10/10, 9:46 PM
Banned
Yepp!! I think the moderated board drove him away!
Old 3/12/11, 6:01 PM
Joseph Hagarty,  CMI's Avatar
Tandem receptacle from today's inspection.
This one was floor mounted.
does-anybody-recognize-type-receptacle-dscf4049.jpg   does-anybody-recognize-type-receptacle-dscf4048.jpg
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 3/12/11, 7:29 PM
James was correct.
Source:
http://nethelper.com/article/AC_power_plugs_and_sockets
U.S. Combination duplex outlet
Left: An extremely old "Nurpolian"-brand black parallel and tandem duplex outlet rated at 250 V 10 A (although this type was normally supplied with 120 V). Right: T-slot duplex outlet.
The parallel and tandem outlet accepts normal parallel NEMA 1-15 plugs and also tandem NEMA 2-15 plugs. Both pair of receptacles are fed internally by the same supply. A more recent and fairly common version of this type is the T-slot outlet, in which the locations of the tandem and the parallel slots were combined to create T-shaped slots. This version also accepts normal parallel NEMA 1-15 plugs and also tandem NEMA 2-15 plugs. Incidentally, a NEMA 5-20 (125 V, 20 A) or 6-20 (250 V, 20 A) plug with a missing ground pin would fit this outlet. This type is no longer available in retail shops since the 1960s.
Old 3/12/11, 7:35 PM
While i have seen this receptacle quite often....
I have yet to see a fixture (tandem plug) that could use this type of receptacle.
Joseph P. Hagarty
Phone: 610-399-3675
Old 3/12/11, 7:48 PM
I understand it to be that it hasn't been available since 1960, and if you read this,
It seems to have acepted later plug sets with two flat blades.
Old 3/12/11, 7:51 PM
Yes.... parallel plugs will still work
has anyone ever seen anything with a tandem plug?
Joseph P. Hagarty
Phone: 610-399-3675
What do you think? Can this work for you? jtedesco1 Electrical Inspections 21 2/26/11 2:00 PM
New type of supply piping mnicholet Plumbing Inspections 11 7/17/08 8:32 AM
Commercial Electrical Inspections jtedesco1 Commercial Inspections 29 1/12/08 5:03 AM
How to Recognize Electrical Code Violations jtedesco1 Inspection Education & Training 5 1/3/06 12:22 PM
