Old 6/2/09, 8:46 PM
Scott A. Hand's Avatar
Scott A. Hand Scott A. Hand is offline
Default Double tapped breaker
They make breakers that can be double tapped. I don't think this is one!
Tandem breaker but double tap can't be right, right?
Cutler-Hammer
BD2020
A2020
Types BRD & A
HACR Type
Find an InterNACHI certified Mississippi Home Inspector (and anywhere else in North America)
Old 6/2/09, 8:53 PM
Default Re: Double tapped breaker
This is what to look for:
Larry Kage, CMI
231 929 3525
Old 6/2/09, 9:04 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Both wires should be the same gauge.
Old 6/2/09, 10:09 PM
So is that a yes or no to my question?
Old 6/2/09, 10:17 PM
It is wrong...
Larry Kage, CMI
231 929 3525
Old 6/2/09, 10:43 PM
That's what I thought too! Thanks for the help!
Old 6/4/09, 9:13 AM
Kevin M. Leonard's Avatar
Kevin M. Leonard Kevin M. Leonard is offline
Cutler-Hammer
BD2020
A2020
Types BRD & A
HACR Type
Thats is a double tap & I call em out every time.
It's hard to tell from the picture for sure but it looks like the wire at the very top of your picture is a 14 guage wire on a 20 amp breaker.
Kevin M. Leonard
The Ohio Home Inspections Company
513-895-7700
937-283-5118
Old 6/5/09, 6:37 PM
Some CH tandem breakers allow 2 conductors per pole. From the picture I can't really tell, but it looks like there are two wire 'saddles' that would imply to me that two conductors are allowed (in certain wire sizes).
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 6/7/09, 9:33 AM
Gerald C. Wilcox's Avatar
Gerald C. Wilcox Gerald C. Wilcox is offline
If you don't call it out and breakers open the circuit when devices are used, you may have liability as having missed the double tap, I always mention them in the report.
Old 6/7/09, 2:50 PM
Paul W. Abernathy's Avatar
Also you need to determine if that panel itself can even have tandom breakers within it to begin with. The panels will say or show in the schematic if tandoms are allowed and if not you should not add them to a panel. Many times we see a 40 circuit panel with a 2-pole main breaker meeting the 42 breaker maximum requirement only to have a bunch of tandoms in it. This violates the listing of the panelboard which is designed for a certain number of breakers and circuits only to have it exceeded by tandoms that are not supposed to go in the panel. Yes they fit but no they are not supposed to be their type senerio.
Paul W. Abernathy,CMI,CPI,CME
pole on double tapped neutrals rdemott Electrical Inspections 10 11/16/08 11:49 PM
Double pole breaker, metal showing between sections lfoster Electrical Inspections 2 9/6/07 1:25 PM
Double Tapped Breaker tjohnson3 Electrical Inspections 8 4/20/07 10:04 AM
Double Tapping a Circuit Breaker Skip Erwin Electrical Inspections 4 2/17/07 8:15 PM
Double tapped GFCI breaker sspradling Electrical Inspections 6 12/9/06 11:51 AM
