hey guys,
i am uploading a picture of the draw inspection report form that i am going to use for this company. my question is, what do the second and third columns figures mean ? the columns in question are Total and % ?? are they samples of previous data ? i thought when they asked for percentage of work done, that would be just it.., a percentage on each item. but now this has me wondering. thanks for your help kevin rea |
Each completed item represents a portion of the total completion of the build.
When Stage 1 is 100% complete, this represents 23% completion of the entire project. Stages are broken down into line items so that portions of other stages can be calculated, even if a particular stage has not been completed. Does that make sense? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
hi Jeff.,
it kind of makes sense. so, under each line item, do i put the percentage of completion up to 100%, or only up to the number quoted in the Total or % column ? like on line one, for site preparation, the first column is 4 and then the second column under % is also 4., does that mean that site preparation is 100 % complete ? let's take another line.. under floor framing/slab/basement: the first column is 23 and the second column is 5, does that mean that it is 21% complete ? kevin Last edited by krea; 10/19/06 at 1:31 PM.. |
If Site Prep is 100% complete, that is the percentage you enter into column 1 (100%). This makes the total job completion 4%.
Now lets say (for example) these items are also 100% complete; Windows Rough-in HVAC Drywall/plaster Counter tops Obviously, other items would need to be completed in order to have these, but this is just an example. 100% of Site Prep = 4% 100% of Windows = 4% 100% of Rough-in HVAC = 1% 100% of Drywall/plaster = 3% 100% of Counter tops = 1% Making the total job completion 13% Now let's add bits and peices; 50% of OS Wall Framing = 3-1/2% 50% of IS Wall Framing = 3% Typically, round numbers are fine, so you would add another 7% bringing the total job completion to 20% It's really simple once it clicks. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
jeff,
so, in the column number 1 , that is now blank, would i be entering the actual percentage completion for that item such as IS Doors, 70 % , for 70% done ? kevin |
That's correct.
They're looking for the percentage complete at each particular line item, so they can pay on that item. For instance, if the drywall budget is $35,000, and it is 70% complete (based on your input), they will pay $24,500. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
thanks for your help Jeff.
kevin |
| NACHI Four Point Form | gbell | Miscellaneous Discussion for Inspectors | 16 | 4/1/08 7:14 PM |
