Old 6/2/10, 10:34 PM
tlemasters tlemasters is offline
Default Drip Legs
Hi Everyone,
With regard to water heaters and furnaces, are drip legs still required? If so, does the flex line connecting the unit to the solid piping qualify if it drops down and comes up vertically to the fitting on the unit?
Thanks so much,
Tom
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/2/10, 10:38 PM
Bob Elliott's Avatar
Default Re: Drip Legs
Answer to first is that it depends on your location.
Answer to second is that does not sound correct.
Old 6/2/10, 11:08 PM
Jim Kolke's Avatar
Jim Kolke Jim Kolke is offline
Thomas~
Drip legs are code for installaton of water heaters in Chicago. The reason behind the drip leg is that there is moisture in the gas supplied from the piping. When the drip leg has been omitted you risk allowing the moisture to pass through the regulator and able to burn through the burner assembly. The gas has moisture in it because it does not have a drip leg and that moisture turns to a caustic steam that adheres to the bottom of the storage tank and can cause premature rusting. The burner and thermal coupling can be changed but the storage tank cant and will cause the water heater to age prematurely. I call all missing drip legs.
Old 6/2/10, 11:25 PM
Brian E. Kelly's Avatar
we do not put moisture in the gas here....so we do not get the dreaded "Caustic Steam".
Old 6/2/10, 11:57 PM
Jeffrey R. Jonas's Avatar
Ya... Arizona has that "dry heat" thing going on!
Old 6/3/10, 7:20 AM
Wayne B. Wilson's Avatar
Not required here also
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 6/3/10, 7:23 AM
Bruce M. Graham Bruce M. Graham is online now
Some manufactures require it
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 6/3/10, 10:02 AM
David A. Andersen's Avatar
You know the device. You know what it does. You know what can happen without it.
Who cares if it is "required" or not?!
BPI# 5015804
Old 6/3/10, 3:31 PM
Jeff Merritt Jeff Merritt is offline
OK. Mr Licensed plumber, This is a question I have been asking for 20 years here in Chicago, roof top units drip legs, yes or no. I have two different answers from Peoples gas. I was told no by a plumber 20 years ago, water would freeze and burst drip.leg what say you.
Old 6/3/10, 9:15 PM
I make a note of it, but i am getting tired of contractors whining
Wayne Wilson
865-256-1490
Drip leg on gas supply line dmonte Plumbing Inspections 5 10/22/09 12:33 AM
Drip leg nbhi Plumbing Inspections 4 6/4/07 11:00 PM
Drip legs Scott Schultz Plumbing Inspections 7 3/31/07 7:46 AM
Condensate in the Drip Pan Skip Erwin Inspecting HVAC Systems 4 7/20/06 11:45 AM
Lack of aluminum drip edge Brenda Exterior Inspections 26 6/16/06 7:28 AM
