If the condensate drain leaves rust stains outside what do you think you will find in the drip pan?
A model A Ford?...........
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Some shack in Scottsdale. Three homes today, all three had bad secondary pans. Splits were good though.
I guess we need to spend more time on the pipe insulation thing!
If you didn't have a good split, you wouldn't have had the stain! |
Haven't seen condensate drains like that come out of the gable ends before.
Typically, from what I have seen, they are always roughed in to the rough framing and discharged directly above the box sill and extend far enough with a 45 degree elbow to not create these stains. Most of the time it will be allowed to run the condensate to an indirect drain receptor that is close by. Then you would not have to worry about aesthetic stains on the exterior. I have heard that condensate provides a chemical creating stains and rust, has anyone heard this? Marcel </IMG></IMG> |
In my opinion, it should not come out the gable end, correct?
If you have any water comming out of the high line it means trouble. |
So what do you think the drip pan will look like once I get into the attic???
Ok here is the attic.
It did get hot and cold though. Last edited by bkelly2; 10/26/08 at 6:42 PM.. |
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
You are correct Marcel, the discharge is "normally" located over a window or door to notify the occupant of the issue. In this case, "Out of sight, out of mind".....
They make some great pan mounted moisture kill switches that would put an end to that particular problem. |
Condensate is a result of refrigeration condensing ambient (R.H) humidity into liquid. The water accumulated is a product of indoor air and rust is from contact with various metal components of the theoretical closed system.
That being said, I don't see the water being discharged to the outside being anywhere close to distilled, nor do I see it being any more caustic than the IAQ of the house the A/C system is conditioning. We use to, by design, run the main drain line off the Evaporative Coil out with the Refrig. L/S, and the secondary or auxillary drain off the drain pan under the Furnace/E.Coil or AHU, out to and eave location over a prominent window or door location. The idea being that if the owner saw water dripping, they knew they had an existing problem or a problem starting with the HVAC system. Action is needed, first, turn the system off as soon as you notice and secondly, call your HVAC service contractor. Algae and other gunk can grow in the various component pans and piping (due to lack of normal maint.) by the Homeowner/Svc. Contr., but I have never seen a real problem with the location of the drain discharge or the water. Note: The discharge of the acidic condensate produced by a H/E 90%+ Condensing Furnace is different, and consideration to a discharge location may be more important, dependent on local codes. |
Let me ask you this. How much rust is too much rust? Short of having a hole in the pan, would it get to a point where you would recommend that the pan be replaced (or further evaluated)?
| Drip legs | Scott Schultz | Plumbing Inspections | 7 | 3/31/07 7:46 AM |
| Asphalt shingle overhang at drip edge | jcampbell | Exterior Inspections | 8 | 11/10/06 7:48 PM |
| Condensate in the Drip Pan | Skip Erwin | Inspecting HVAC Systems | 4 | 7/20/06 11:45 AM |
| Lack of aluminum drip edge | Brenda | Exterior Inspections | 26 | 6/16/06 7:28 AM |
