I heard today that this is becoming a common problem:
Dryer vents clogging up quickly due to condensation inside the uninsulated duct. The clog is occurring up near the roof termination point. I guess this could occur on ones that run horizontal to a wall too. I'm going to start recommending these ducts be insulated starting with a predrywall I did today. Also, I have started seeing more insulated condensate drain pipes in attics too (new homes). With the larger homes and owners that run the A/C a lot, there can be a lot of dripping condensation off these pipes into the attic insulation/sheetrock. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Find an InterNACHI certified Michigan Home Inspector (and anywhere else in North America) |
How long is the run that these are clogging up on Bruce?
Insulating a dryer vent seems extreme to me. What do you have to base that recommendation on? (You're going to make your Realtor friends mad!)
I just say this: "The dryer vents vertically. The lint trap must be kept clean, because trapped lint can rapidly turn into a fire hazard. Inspection of the vent every 6 to 12 months is recommended to ensure it is not clogged." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Pretty common in dry south west locations and W. Texas but it doesn't get very cold and the dew point tends to be very low. I would guess that a big part of the problem is that no one ever cleans the lint out of the exit point since it's up on the roof.
I see some here in KC. I always have a concern about snow covering the vent.
Realtor friends? ha! You know better than that! A maintenance guy for a homebuilder told a friend about this, he said its becoming a major issue for them. Not sure if he is working for the builder or working on the side but that does not matter. The typical roof run is probably 20-30 feet depending on the pitch, ceiling height etc. I agree with keith, the problem could be less if these outlets got cleaned once in a while, its just bad design to assume homeowners will do any maintenance. Nothing wrong with recommending upgrades as long as they are stated as such. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Thanks for the post Nick. I am always looking for good safety and informational links for my website.
Robert Sole, CMI 407-637-7288 Florida license numbers HI 169 and MRSA 92 Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties. RobertSole@REMinspections.com Check out my blog orlandohomeinspections.info/ REMinspections.com OrlandoHomeInspector.net |
Cincinnati Ohio Home Inspection Services |
I just recently came across a dryer vent that entered the crawl space before exiting through the wall. The ribbed flex vinyl was completely torn apart and judging by the pounds of lint strown all over the crawlspace, it has been for quite some time. It gets worse too. Although the residence was currently empty(including the dryer), and there were gas and hydro hook-ups available, I could tell by the teflon paste apparent on the gas fitting that it was likely gas exhaust pumping straight into the three bedrooms immediately over that portion of the crawlspace. Those flexible ribbed vents should always be listed a defect.
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Or through a Garage Cabinet terminated in a Cabinet.
I had one yesterday that was venting over a lower roof. The shingles (below) were full of lint.
A dryer vent booster fan should be installed if the run exceeds 25'. This is determined after taking into acct. the 90 degree turn reduces it by 5' and the 45 degree turns reduce it by 2.5'. Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 7:31 AM |
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 11:50 AM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
