Old 8/6/09, 4:30 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default Electrical box in a garage ceiling
Does an electrical box in a garage ceiling violate a firewall standard? Do you call this out? Do you know of any jurisdictions that have commented upon the apparent opening of the firewall of the garage ceiling by an electrical box/outlet/receptacle/fixture?
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Find an InterNACHI certified Tennessee Home Inspector (and anywhere else in North America)
Old 8/6/09, 4:44 PM
Brian E. Kelly's Avatar
Default Re: Electrical box in a garage ceiling
J-Box, outlet box?? Metal boxes are not combustible.
Old 8/6/09, 4:48 PM
Metal boxes are not air-tight either. Regardless of the material of the plate cover or the electrical box, isn't there a pathway for fire through there? Does anyone have any code references? (a metal electrical box is not equivalent to a firewall material - yes?)
BEN GROMICKO
Old 8/6/09, 5:01 PM
Michael R. Boyett's Avatar
Ben, the 2006 IRC says:
R309.1.2 Other penetrations. Penetrations through the separation
required in Section R309.2 shall be protected by filling
the opening around the penetrating item with approved material
to resist the free passage of flame and products of combustion.
Commentary:This section addresses the annular space which results
from a penetration of the common wall by pipes,
conduits or ductwork. It is important that the code official
verify that these spaces are properly filled and do
not compromise the protection offered by the common
wall between the residence and garage against the
free passage of smoke, fire, noxious gases and odors
That doesn't specifically answer your question but that's what I see on quick glance. The underlined (mine) section seems to indicate that even j-boxes should be considered improper penetrations unless somehow filled, fire-stopped or (as Brian points out) rated for such.
Old 8/6/09, 5:47 PM
http://www.alliedmoulded.com/Ceiling...%209-25-06.pdf
http://books.google.com/books?id=guY...age&q=&f=false
Perhaps you should get Nick to buy you a code book or two Ben.
Old 8/6/09, 5:57 PM
I don't read. I only learn from video.
That information is great stuff. But during an inspection, what do you say to your client (if anything). What is your narrative (if you have one) about the electrical box in the garage firewall ceiling?
BEN GROMICKO
Old 8/6/09, 7:44 PM
Video, excellent. I do not say anything Ben. But I am thinking about that now. Dangit Ben.
Old 8/6/09, 8:10 PM
rbibler rbibler is offline
Please Note: rbibler is a non-member guest and is in no way affiliated with InterNACHI or its members.
What happed to the the GURU GUY ?
In Calif The panel needs to be rated for this application. But i don't think I have ever had one in a garage. All main panels are on the out side and all service panels are on the interior some place.
Best
Ron
Old 8/6/09, 9:09 PM
Best
Ron
Ron, think garage door outlet box.
Old 8/6/09, 9:19 PM
Its been a long day
Best
Ron
Old 8/6/09, 9:45 PM
Its been a long day
Best
Ron
No worries Ron.
Old 8/6/09, 10:28 PM
Not to change the subject, but ...
What about attic pull-down stairs in the garage? I often find that they have been installed by the homeowner, are apparently not fire-rated, have a exposed 1/4-inch thick plywood panel, and are not air-tight at the seams.
If the firewall of the garage does not extend up to the roof sheathing, then the pull-down is a breach in the firewall.
If there is a firewall that extends up to the roof, the pull-down is still a problem. The pull-down allows fire to be sucked into the attic. Since the pull-down is not air-tight, and there's a natural low pressure in the attic space, then gases, smoke and fire could be naturally sucked up into the attic space.
If the attic pull-down in the garage ceiling is not obviously labeled as fire-resistance rated, I flag it.
BEN GROMICKO
Attic fan in garage ceiling cowen Exterior Inspections 10 8/20/11 5:53 AM
Commen Electrical Codes bboerner Electrical Inspections 1 5/11/09 10:50 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Dwelling and Commercial Electrical Equipment jtedesco1 Electrical Inspections 4 1/10/08 6:46 AM
Handbook for Electrical Safety pabernathy Electrical Inspections 1 1/1/07 1:14 PM
