Old 10/19/11, 5:25 PM
LeRoy D. Holm's Avatar
LeRoy D. Holm LeRoy D. Holm is offline
Default Electrical Panel Defects
Inspection today had a interesting electrical panel, How many defects do you see. I was told they upgraded from fuses and from the exterior service I expected a 100 amp panel.
This what I got.
I wish I had taken more pictures, there was also water lines above and beside it and no clearance in front.
electrical-panel-defects-troester-033.jpg   electrical-panel-defects-troester-034.jpg   electrical-panel-defects-troester-009.jpg
www.tristatehomeinspections.org
www.tristateenergyinspections.com
If you always do what you always did you will always get what you always got.
Old 10/20/11, 12:31 AM
jguillen jguillen is offline
Please Note: jguillen is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Electrical Panel Defects
DOUBLE TAPPING OF NEUTRALS IS A CODE VIOLATION A HAZARDOUS Situation see nec 408.41 each neutral needs to be individually in its terminal also see article 110 each terminal is intended for 1 wire only and the service wires feeding panel are detiorated and the lower voltage wires coming down with feeders is un acceptable to me it is a noncompliance write -up i will call it a failed inspection from JOSE A. GUILLEN ICC
Coming to Schaumburg, Ill - Electrical Training with The Electrical Guru ksitzes Inspection Education & Training 12 3/17/10 4:19 PM
Download the videos here all about physics and electricity jtedesco1 Electrical Inspections 5 9/14/08 3:58 PM
Electrical Safety Foundation International Links jtedesco1 Electrical Inspections 5 12/8/07 3:10 PM
Electrical Safety Information jtedesco1 Electrical Inspections 0 2/19/06 1:48 AM
