Old 1/27/11, 8:05 PM
Philip J. Cavalcante Philip J. Cavalcante is offline
Default Engineer or not
OK need everyones thoughts here. The area in question is the front left corner right next the the bush. There is damage to the block of the foundation it looks to be washout due to the fact that the down spout was draining right on that corner. There is no damage to the porch pad or structure. My question is what do you guys think the fix would be and do you think i should call in a engineer.
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/27/11, 8:29 PM
Default Re: Engineer or not
Looks to me like the foundation is a little to shallow in the ground and the frost acted upon the porch foundation enough to make that parging crack.
How was the house foundation on that side.
I don't know the frost depth in your area, but that is the first thing that came to mide.
I don't think you need an egineer, but you might want to recommend a landscape Architect and a Concrete foundation contractor to make the repairs.
Old 1/27/11, 9:01 PM
Brian E. Kelly's Avatar
Agree with Marcel, I generally call out a Foundation Contractor here if think a repair is necessary.
Old 1/28/11, 6:11 AM
Thanks guys there was no other damage to the foundation just wanted to get some other opinions.
Old 1/28/11, 9:56 AM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
I never call out for only a foundation contractor, even when that's all that's needed. Maybe it's because I'm from NY and we have a glut of starving attorneys around here.
I may offer my opinion, and definitely report on the defect. I never suggest a repair or course of action.
I always recommend follow-up by a licensed professional engineer if the clients wants further evaluation. I may mention a foundation specialist, but always insert the PE in the write up.
Why? Because in NY, only the opinion of the PE counts in court.
Whether or not the client chooses to call a PE is up to them.
I inform, they decide.
But, in reality you're right. A foundation guy will repair this in a satisfactory manner, without much problem.
Old 1/28/11, 10:48 PM
David G. Lightner's Avatar
David G. Lightner David G. Lightner is offline
Your right Joe. Same down here. Always a PE. The rest is up to them.
David
Edison, NJ 08817
(848-565-7741)
Old 1/28/11, 11:12 PM
Foundations here in AZ are Engineered Systems, therefore Foundation Contractors here, have their own Engineers working for them.
Calling a PE, to tell a Client they need a Foundation Contractor to make a repair is redundant, IMO.
Old 1/29/11, 5:43 PM
Banned
What's up with NY engineers? I read an article or blog (2-3 years ago) in which an NY engineer was making a case that only engineers were qualified to inspect houses!! Is this idea gaining traction? Or some P. Eng speaking out his ---?
Old 1/29/11, 6:10 PM
Kenneth Dolin's Avatar
Kenneth Dolin Kenneth Dolin is offline
I think thats a profound statement Joe, I have been in the habit of just calling out what it is that I see, not making diagnosis of the problem or recommending a specific repair or for that matter putting into the report that a Licensed whomsoever is needed. It is clearly none of my business who is hired to make a repair, only that if I do the re inspection, the repair was done properly based on the information visible and or provided to me.
Of course nothing is written in stone and each inspection and problem that comes up is different and requires a different course of action.
Ken Dolin
Kenco Home Inspections
WWW.Kenco.org
State of Florida Licensed Home Inspector HI 59
Why Use a Full Time Professional Inspector Instead of an Engineer? jbushart Miscellaneous Discussion for Inspectors 16 12/6/10 11:15 PM
Cut floor joist ok with engineer bking Structural Inspections 15 9/23/10 4:38 PM
Engineer Botches Home Inspection...Suspended by Regulating Agency jbushart Miscellaneous Discussion for Inspectors 0 1/25/08 5:58 PM
Discounts for first inspections? sdavies Canadian Inspectors 99 1/30/07 11:40 PM
