LinkBack | Thread Tools | Display Modes |
A lot of new construction around here has bathroom fans that discharge into the insulation somewhere, hard to find and prove so today I turned on the showers on fairly hot with the fans running in 2 baths. Went back in after just 2 minutes and it was a steam room.
Even the cheapest fans available will prevent that! thinking about getting some of those smoke sticks now for the houses with no hot water. |
rcooke is a non-member guest and is in no way affiliated with InterNACHI or its members.
Roy cooke sr |
I use the toilet paper also. I also run the fans for the attic inspection to make them easier to locate if buried.
Adam, A Plus |
| Display Modes | |
| Basement Bathroom Venting Question | Sean M. Jeric | Plumbing | 4 | 3/21/07 12:56 AM |
| Online Code Check- Reference | pabernathy | Electrical | 31 | 11/9/06 4:39 PM |
| Venting a bathroom in a highrise condo | Mark Ellison | HVAC | 1 | 10/9/06 12:00 AM |
| Soot around the bathroom vent | lclark | Exterior | 7 | 3/6/06 9:13 AM |
