Does anyone know where I can get a copy of what a lending Institution is looking at for an FHA mortgage. There must be some kind of list of requirements.
Thanks Frank |
| Find an InterNACHI certified Ohio Home Inspector (and anywhere else in North America) |
Yep...look at some of my posts and you will see
Frank,
I do FHA/VA inspections quite a bit. The banks simply need a special form (NPMA-33) filled out by you. I use paper forms right now but they are no longer selling the paper forms. You must now go on-line to sign up and do everything on their website. The NPMA-33 forms can now be emailed to your clients. Go HERE and sign up. |
NPMA-33 is for wood destroying insects.
Very good observation, Gary.
That's what FHA lenders require at closing. |
So if I am not certified to do pest inspections, should I still take on the inspection and just take a pest inspector with me?
Mike Jewett is a non-member guest and is in no way affiliated with InterNACHI or its members.
Further- how does one get certified to do WDO inspections?
Your pest inspector should have the NPMA-33 forms. If not... find a pest inspector that does have the form.
In Kansas, a WDO is not required by some FHA lenders. The laws vary by state. In Kansas, you have to be licensed to do WDO inspections, as well as most midwest states. Again, rules vary by lender. Just about anyone can get the forms from CrownMax.
Around here they have an FHA inspector look at habitability and safety issues only.
Most good agents will warn buyers that they need a real home inspection too. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
http://www.npmapestworld.org/store/p...s.asp?CatId=10 Gary Oleski Home Inspections Home Inspections Connecticut Connecticut . 06610 NACHI04012833 CT#HOI.341 C M I
I have done lots of Inspections for clients getting FHA loans and was never requested to fill out any special forms.
From what I heard it just needs to be habitable. ?????what gives? www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 4/29/09 at 12:48 PM.. |
Bruce, you are correct. There are only different froms for HUD inspections. Most all FHA lenders will accept iNACHI inspector's inspections. The difference is in the lender; not the FHA. I have never in 9 years had an issue with any FHA lender accepting my inspection reports. However, if they require a termite inspection, the NPMA-33 form must be used, which I use for all of my termite inspections anyway.
Many underwriters are requiring that the appraiser inspect and report on specific issues. The requirements vary by lender and have no real rhyme or reason, in fact, some are down-right absurd - I had an appraiser ask to borrow my ladder because he needed to "report on the condition of the trusses in the attic." I informed him that he could not borrow my ladder and that this particular flat-roof home does not have a truss system.
Appraisers are being put into a difficult position with these loans. It's only a matter of time before this process results in lawsuits against the lender and appraiser. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Agreed. I ran into an appraiser yesterday. He told me to be sure to write up the furnace, since the furnace was in the garage, it needed a post in front of it to protect it from a vehicle. I asked him if he was a code inspector. He said nothing, and left about 30 seconds later. I bet he came back after I left. Here in Kansas, appraisers will be exempt from any home inspection laws, rules and regulations. They are already starting to report back to the lenders about home defects. I cannot wait for an appraiser to go to court for some defect that they called out. Just put them in their place; not yours.
| Florida Licensing Bill - Action Soon | jburkeson1 | Legislation, Licensing & Legal Issues for Inspectors | 250 | 7/1/10 4:50 PM |
| Liability question | jcahill | Legislation, Licensing & Legal Issues for Inspectors | 30 | 8/24/08 4:10 PM |
| Importance of the AHJ check | mcyr | General Inspection Discussion | 6 | 2/21/07 8:18 PM |
