Old 5/18/10, 2:24 PM
dwilliams9 dwilliams9 is offline
Please Note: dwilliams9 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default FHA Ispection
I was contacted to do a FHA inspection on a new construction house. I am listed as a FHA Inspector, but I have never done one before so I turned it down because I didin't want to screw it up. I'm looking for a little direction on how to perform the inspection, what forms to fill out. Is it a normal home inspection? What is your guys process? Any help would be very helpful. I hate leaving money on the table.
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/18/10, 6:26 PM
James E. Braun, CMI's Avatar
Default Re: FHA Ispection
Was it a 203K?
A manufactured home foundation?
Need more info.
Old 5/18/10, 6:32 PM
John Harrison's Avatar
John Harrison John Harrison is online now
I would be glad to assist in answering questions if you want to call.
712-326-4320
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas
Active Rain Member
Old 5/19/10, 12:06 AM
Paul Pendley Paul Pendley is offline
If you are listed as a fee panel inspector one of the requirements for this is knowing what to do. Im confused as to why you dont know. Just asking. Feel free to contact me and I will steer you in the right direction if someone hasnt already.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 5/19/10, 8:41 AM
Rodney Glasgow Rodney Glasgow is offline
I'm a new inspector and all this is new, but I did inquire concerning FHA inspections recently. I contacted a rep in Indianapolis and another seasoned inspector and was told that FHA inspections have changed. The FHA recommends that their clients use licensed inspectors. I think this was part of the problem before and the reason you had to be on the FHA approved list to do an inspections. There were too many doing inspections that were not qualified or licensed. I also know that clients getting FHA loans have to have certain water test performed if there is a well on the property so make sure you check this out also. There maybe more information that I'm not aware of but I hope this is a start.
Old 5/19/10, 8:48 AM
ldapkus ldapkus is offline
I think many people confuse Fee Roster Inspectors (203k) with REAC inspectors.
Old 5/19/10, 10:57 AM
Sorry, no such thing as a licensed inspector in the state of Utah. No well on property either. No water test required.
Old 5/25/10, 7:51 AM
jrooney jrooney is offline
dwilliams9
The following is part of the qualifications required by FHA. How you circumvented the process is beyond me but if you put your signature on this application to be considered a fee inspector then you are either ignorant or not being honest. You can not possibly have read any of the required material and still be unaware of how to do an inspection. Maybe you should withdraw your name as there are criminal penalties involved. And why anyone would willinglyhelp you get over and scam someone is also beyond me. I am on the FHA roster and it took some extensive reading to understand what was expected. If you can't do even that little bit then you shouldn't be on the roster.
(f)
For Inspectors, I certify that I have a minimum of three years experience in one or more construction-related fields and that such experience has equipped me with a thorough familiarity and understanding of residential construction techniques as related to new construction and repairs of a structural nature. I certify I will conduct my inspections in accordance with HUD/FHA requirements. I further certify that if licensing or certification is required by the state or local jurisdiction(s) in which I will operate, I will maintain such licensing or certification in good standing with the applicable jurisdiction for the duration of my tenure on the FHA Inspector Roster. I further certify that I have read and fully understand the inspection requirements, including any update to those requirements, including Mortgagee Letters, in performing all inspections on properties that will be security for HUD/FHA insured mortgages and contained in the following documents:
(i) HUD Handbook 4905.1 REV-1 (Requirements for Existing Housing, One to Four Family Units);
(ii) HUD Handbook 4910.1 (Minimum Property Standards for Housing);
(iii) HUD Handbook 4145.1 REV-2 (Architectural Processing and Inspections for Home Mortgage Insurance);
(iv) HUD Handbooks 4150.1 REV-1 (Valuation Analysis for Home Mortgage Insurance) and 4150.2 CHG-1 (Valuation Analysis for Home Mortgage Insurance for Single Family One to Four Unit Dwellings);
(v) Permanent Foundations Guide for Manufactured Housing (formerly known as HUD Handbook 4930.3G, Permanent Foundations Guide for Manufactured Housing);
(vi) All applicable local, state, or Council of American Building Officials (CABO) code(s) for the jurisdictions in which I will operate; and
(vii) The HUD requirements at 24 CFR 200.926
Old 5/25/10, 8:59 AM
Bruce A. King's Avatar
FHA inspections for the most part around here are driveby, lame as hell inspections. I had a client that suspected that and went ahead and hired me after the FHA guy gave it a green light. I found $150k worth of issues.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 5/25/10, 10:09 AM
Chuck Lambert Chuck Lambert is offline
Unmoderated Guest
Please Note: Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
The FHA inspections are NOT a full blown home inspection they only have specific things they look at. They have their place and can be quite profitable when you get hooked up with the right mortgage company.
Chuck
Old 5/25/10, 10:10 AM
Unmoderated Guest
FHA fee roster inspectors are different than 203K consultants.
Chuck
Old 5/25/10, 10:20 AM
mnahrgang's Avatar
Originally Posted by jrooney View Post
...You can not possibly have read any of the required material and still be unaware of how to do an inspection....
I disagree. There is so much junk there that you have to sift through, it's very confusing. An no where in that entire pile that you quoted does it spell out the requirements of a fee inspector in simple terms. The information is primarily for mortgage bankers, and appraisers.
Mark Nahrgang
www.HeyMark.info
Old 5/25/10, 12:42 PM
Robert W. Jude's Avatar
Robert W. Jude Robert W. Jude is online now
its a cluster fudge. the right lenders are helpful and should get you started. after that it's a piece of cake. keep in mind no one else understands the 10 million pages of red tape either and then everyone has their own interpretation anyway. bottom line is you have to satisfy the lender's requests and cover your butt- and do that all on the correct government forms.
Old 5/25/10, 4:00 PM
Mark
No disagreement about that. But isn't that the price of admission? The OP doesn't mention that at all. So I question how he is listed as an FHA inspector. I was accepted only last year after I had gone through all the reading. Did I read it all? NO I read all that pertains to Inspectors though. Within a few weeks and as time permitted I was able to understand all the forms I needed. Upon review of those forms I had only a few questions. I called FHA and after being bumped from person to person I was connected to a man who answered all my questions.
Think of it from a point of ethics. The Minimum standards only require reading and making a few phone calls. And the OP (original poster) hasn't responded to me. I'm still curious how he is listed as an inspector yet doesn't have a clue.
Old 5/25/10, 4:16 PM
mnahrgang's Avatar
Mark
Your experience is unusual. I tried to find the pertinent sections and was unsuccessful. If it wasn't for the help of a lender who sent me a copy of one already filled out, I would have been lost. So lighten up on the OP.
My "help" experience with FHA was less than helpful. I sent them an e-mail requesting instructions and specified where I had already looked on their web site. The response I got back was pre-canned and pointed to the exact page that I specified wasn't helpful.
BTW, the only form I'm aware of for a fee inspector is the 92051.
If you are aware of others, you could be helpful here and help educate the OP as well as myself (I've been doing these for a couple of years now with few complaints, and those come from lenders who expect me to put escrow amounts on the form for them.)
Mark Nahrgang
www.HeyMark.info
