Old 8/13/07, 8:31 PM
James B. Michael James B. Michael is offline
Default Fire Doors / tags
Looking for information on Fire Rating tags on service doors...
Old 8/13/07, 8:48 PM
Default Re: Fire Doors / tags
James, start with this and see if it helps, if not let me know so I can assist.
http://www.steeldoor.org/pdfs/118.pdf
Marcel
Old 8/16/07, 5:50 PM
Wilfred O. Hellner Wilfred O. Hellner is offline
Send a message via AIM to whellner
I am a member of NFPA . what exactly are you looking for? the tag itself? or what rating the firedoor should have in that fire wall or smoke wall?
Will Hellner Florida Licence # HI103
Old 8/16/07, 7:33 PM
Notes on Fire Door Requirements
  1. Fire rated door assemblies require a labeled door, a labeled frame, a listed lock device, listed closing device, and steel bearing hinges. Non-steel bearing hinges are acceptable as tested on listed assemblies.
  2. In general, the required hourly rating of the door assembly is 3/4 of the hourly rating of the wall it is being installed into.
  3. The minimum rating of any component in the assembly determines the achieved rating as the assembly: a 1 1/2 hour door installed into a 20-minute frame results in a 20-minute assembly.
  4. Subdivision of non-rated components or devices in the door assembly can only result in a reduction in or a voiding of the overall fire protection rating.
  5. Most fire door installations are governed by NFPA 80- Fire Doors and Windows.
http://www.benchmarkdoors.com/Buildi...ireCodes.shtml
Marcel
Escape, Fire & Smoke Alarms badair Interior Inspections 14 1/28/08 8:21 AM
Good man rcooke Canadian Inspectors 3 12/4/06 11:38 AM
The Fire Guy ccrooker Canadian Inspectors 0 3/8/06 12:11 AM
