Does anyone know when 1hr firewall became code between garage and living area of the home?
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It doesn't matter to a home inspector.
It is recommended where it is not present no matter when the house is built. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Understood.
But in TX I can't mark it Deficient unless it violated code when it was built. |
That's not accurate Craig
Good idea. I cover all the bases that way, point out the problem without "penalizing" anyone, and CMA.
Thanks for the diplomacy lesson. Craig (preferred name) |
"Although not required when originally built, you may wish to upgrade the (blank) to (blank) for safety reasons.."
Or a reasonable facsimile thereof.......... |
Let's say that the issue is electric and the requirement you are referring to was first required in the 2002 version of the NEC. Can you say that, since the house was built in 2003, that the 2002 requirement would apply? What if, in that particular jurisdiction, the 2002 NEC was not accepted by the municipality until 2008? I have a small town about 19 miles from me that still goes by the 2000 IRC. Just because a particular item appeared in a code book on a particular date, it does not mean that in the jurisdiction that you are inspecting in, the requirement was put into effect on that particular date. So....relax. Your recommendation to your client is not contingent upon dates, code books or AHJs....but your knowledge of a safer or more structurally sound method. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Sure takes the stress out of the job ,when you do not need to puff out your chest and act authoritative.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Thanks to you all for your help, and particularly you Chuck for reminding me where to look first.
Sometimes we can't see the forest for the trees. |
You still have no need for dates though , as safety has nothing to do with them.
Paul W. Abernathy |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Basement Bathroom Venting Question | Sean M. Jeric | Plumbing Inspections | 4 | 3/20/07 11:56 PM |
| Another Firewall Question? | dsmith1 | Interior Inspections | 9 | 2/10/07 6:35 PM |
