What other recommendation you would suggest to a client when you find mold in a house?
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
This is in no way meant to be a slam. But if your asking this question you should automatically defer them to a professional dealing with the sitaution and then leave it alone. Offer NOTHING else, but to seek professional guideance. Mold assessor is the right person to send them to and can be found on the DBPR website.
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Determining the source is the first step. Eliminating it is the second. Remediating the mold and repairing any existing damage is the third. There are professionals who specialize in each of these steps. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
What's the difference between eliminating it and remediating it? You hire 1 firm to eliminate and another to remediate?
Eliminating the source. That must be done prior to remediation of the mold.
I consider that part of the remediation when the source isn't apparent.
To do otherwise is a rip-off. Unsuspecting consumers will be repeatedly paying for additional remediation efforts until finally correcting the issue causing the mold colonization ... which can be significantly less expensive than the remediation. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
I also agree with you James.
The only person to find the moisture problem should be knowledgeable in all areas of water intrusion and vapor control. IE: A Certified Environmental Inspector. Remediation cleans and removes mold not fix the mold problems. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Must be different in different areas. Mold remediators here all fix the source before ANYTHING happens. I just assumed it was that was everywhere. Guess I was wrong.
Not in my area.
Any real mold remediation protocol, I have seen, states that what source of moisture caused the mold needs to be corrected at the beginning of the recommendation or procedure page. Sometimes you do not know the true cause of the moisture until the affected porous materials are removed. ANSI/IICRC S520, Standard and Reference Guide for Professional Mold Remediation, Second Edition requires an Indoor Environmental Professional to evaluated if there is a sizable amount of mold (I do not remember the exact wording off the top of my head). The mold industry has established many rules when it comes to mold, they just need to be followed.
I just got done working on a legal case and during my research I have discovered OSHA actually has a procedure for the removal of mold. The procedure is not totally right (they need to use more current studies) but it is better then nothing at all. Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
A regular contractor can reinstall the porous materials without fixing the moisture problem and probably get away with it, because he can make the case the homeowner knows the leak needed to be fixed and he did not, because he did not see the mold remediation protocol. A mold remediation protocol is a legal document (at least that is how a court sees it) if ignored, whoever ignored that document is responsible, nobody else. There is sometimes, I do not bother to write a mold remediation protocol if I feel parts of it is going to be ignored. It saves everybody the big argument. Sad but true. Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
| Fighting Mold — The Homeowners' Guide from CMHC | mkyriacou | IAC2 Indoor Air Forum | 1 | 9/17/09 2:32 PM |
| That which is visible is mold | bgromicko | IAC2 Indoor Air Forum | 118 | 9/2/08 4:59 PM |
| Mold Drives 2nd family from home | dplummer | Ancillary Inspection Services & Additional Topics | 0 | 7/10/08 6:25 PM |
| Stupid ASHI legislatin in Washington DEAD. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 20 | 1/29/08 9:05 AM |
| smoke or mold? | rjack1 | Interior Inspections | 31 | 12/19/07 7:46 AM |
