Does anybody know what year foundation Bolts were required?
Preston Sandlin www.homeinspectioncarolina.com www.charlottenchomeinspector.com www.askthecharlotteinspector.com |
| Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Preston,
It depends on the actual code inspector, somewhere around the mid 90's straps or bolts started showing up in some areas on some houses. Even now they are loosely enforced it seems. I would not make a big deal out of it unless it was still under the builders warranty period. I had a house once that was built in 1986, no straps/bolts and it got hit with 95 mph winds during hurricane Hugo. No insurance claims or issues other than a small roof leak where the shingles were already cracked. Be advised there are some one-tab type simpson straps that "could" be used where they are only put on the outside and not visible during an inspection. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Somewhere around 1935 in CA. . .
dquigley is a non-member guest and is in no way affiliated with InterNACHI or its members.
| Dampness in basement- new construction | jcundiff | General Inspection Discussion | 47 | 6/21/08 11:35 AM |
| Metal straps instead of anchor bolts on slab foundation | lfoster | Structural Inspections | 9 | 8/8/07 8:24 AM |
| Foundation bolts | gbrasseur | Exterior Inspections | 35 | 11/30/06 7:33 PM |
| No Foundation Bolts | thejnicki | Structural Inspections | 7 | 8/26/06 2:27 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 4:52 AM |
