Old 6/12/08, 2:57 PM
tlorenz's Avatar
tlorenz tlorenz is offline
Default Foundation question
I am curious as to your thoughts on this situation. Cinderblock foundation and a diagonal crack running down to the floor and starting beneath a window. Clients questions are:
1. Can the crack be sealed? (I'm thinking roofing tar, caulk or something of that sort).
2. Will they have to do major repair to the foundation within the next 10 years?
The house was more than 40 years old and this was the only significant issue I saw with the foundation.
Should I recommend a further look from a contractor, or maybe a structural engineer?
Thank you!
Terry
Old 6/12/08, 3:24 PM
Frank Magdefrau's Avatar
Frank Magdefrau Frank Magdefrau is offline
Default Re: Foundation question
You need to know on site the correct way to report a foundation crack, however if you are not sure the "moderate crack" concerns works well.
One or more minor cracks (1/8 inch or less) were found in the foundation. These don't appear to be a structural concern, but recommend sealing them to prevent water infiltration and monitoring them in the future. Numerous products exist to seal such cracks including:[*]Hydraulic cement. Requires chiseling a channel in the crack to apply. See http://www.quickrete.com an example.[*]Resilient caulks (easy to apply). See http://www.quickrete.com for an example.[*]Epoxy sealants (both a waterproof and structural repair). See http://www.mountaingrout.com/ for examples of these products.
One or more moderate cracks (1/8 inch to 3/4 inch) were found in the foundation. These may be a structural concern, or an indication that settlement is ongoing. The client(s) should consider hiring qualified contractors and/or engineers as necessary for further evaluation. Such contractors may include:[*]Foundation repair contractors who may prescribe repairs, and will give cost estimates for prescribed repairs[*]Masonry contractors who repair and/or replace brick veneer[*]Geotechnical engineers who attempt to determine if settlement is ongoing, and what the cause of the settlement is[*]Structural engineers who determine if repairs are necessary, and prescribe those repairs
At a minimum, recommend sealing cracks to prevent water infiltration. Numerous products exist to seal such cracks including:[*]Hydraulic cement. Requires chiseling a channel in the crack to apply. See http://www.quickrete.com for an example.[*]Resilient caulks (easy to apply). See http://www.quickrete.com for an example.[*]Epoxy sealants (both a waterproof and structural repair). See http://www.mountaingrout.com/ for examples of these products.
One or more major cracks (more than 3/4 inch wide) were found in the foundation. These appear to be a structural concern, and may indicate that settlement is ongoing. The client(s) are strongly advised to hire qualified contractors and/or engineers as necessary for further evaluation. Such contractors may include:[*]Foundation repair contractors who may prescribe repairs, and will give cost estimates for prescribed repairs[*]Masonry contractors who repair and/or replace brick veneer[*]Geotechnical engineers who attempt to determine if settlement is ongoing, and what the cause of the settlement is[*]Structural engineers who determine if repairs are necessary, and prescribe those repairs.
Thanks to www.reporthost.com
Frank Magdefrau
Certified Master Inspector
DeSoto Home Inspection Services, LLC
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
InterNACHI Member since 2002
InterNACHI message board member since 2003
InterNACHI ESOP member from 2004 to 2010
Old 6/12/08, 5:26 PM
James E. Braun, CMI's Avatar
Are you sure about it being cinder block? Looks like poured concrete formed with boards.
From the pictures it does not look like it is major for that old of a house but I am not there to make that call. Is there any shifting side ways at the cracks?
I have not seen a cinder block foundation that does not leak.
Old 6/12/08, 5:36 PM
James,
You are correct, this is a concrete foundation built on site using 1"x6" boards with ties and waler system.
This foundation must have been built in the fifties.
That crack under the window, has probably been there for years, and if it don't leak would be of no concern.
Obviously, reiforcement then was little to none, so note it as a crack and if it starts leaking to have a waterproofing contractor address it. If conditions change for some reason, it could be a problem in the future.
Recommend a foundation contractor to assess the repairs required.
Hope this helps.
Marcel
Old 6/12/08, 9:09 PM
jbettencourt jbettencourt is offline
Please Note: jbettencourt is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree with the above opinions, and tell them to get rid of the plastic dryer vent and get a proper metal one.
Old 6/13/08, 7:40 PM
RB Who ever the hell your are;
Foundation question 6/13/08 9:34 AM Where else would you build a concrete foundation wall?...rb
I am going to tell you one thing, I am sick and tired of you giving me a red for every post I make.
If you have a problem with what I say, call me, email me, private mail me, but anything but insulting me with these reds.
I have poured more concrete in my life than you will or have seen.
I have formed concrete with 1"x6" boards like I stated.
I have tied concrete forms in fireplace footings with # 9 wire by crawling inside.
I have built foundations for over 40 years, and yes that makes me an expert, more so than I can say for you.
I know when a foundation crack is a problem, and I know when damp proofing is used and called a waterproofing.
Is there anything in particular that you would want to shed some light on?
Maybe I can teach you a few tricks or so, and you might even double your inspections by half of what you have now.
You might even show people you know what the hell you are talking about.
It is obvious that you have something on me, because this is about the 6th red I get from you.
If there is a way to find out who you are,. I will.
Oh and thank you for your time and effort in reading the post to begin with.
I just hope you spend the time to read this one.
If you need any help in finding a job you can handle let me know, I hear that the Sanitation Engineers here in town, need help.
</IMG></IMG>
Old 6/13/08, 7:49 PM
mnahrgang's Avatar
Marcel,
If you place your mouse over the green boxes of your post, you will see that you "have a reputation beyond repute."
It was said in another thread, that if you want the greens, then you have to be a little thick skinned with the reds too. Otherwise turn the system off in your preferences.
I think you're a great help around here, and when I can give you another green (after I've spread some around first), I'll be giving you more.
Bottom line, try not to take it too personally, at least he gave his initials.
Mark Nahrgang
www.HeyMark.info
Old 6/13/08, 7:55 PM
Thank you Mark.
It is just frustrating to see that some people cannot appreciate the help, or ask for some elaboration of the topic.
And when it is always the same one, it is like a poker in your side.
I am here to help all and as many as I can that are out there trying to make an honest living.
Sharing ones knowledge is the best I can do, and it hurts when one refuses it due to his own ignorance and stabs at the giver.
Thanks
Marcel
Old 6/13/08, 8:06 PM
William J. Decker's Avatar
Marcel;
For what it is worth, I agree with you.
Concrete foundation with vertical crack, inject urethane if seeping.
Replace the plastic dryer vent hose. Safty hazard.
You are always helpful to me, Marcel (just stop doing mime )
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 6/13/08, 8:13 PM
Originally Posted by wdecker
Marcel;
Thanks Wil and hope things are going good for you.
You have me questioning myself as to what I am suppose to stop with this word above, what did you mean?
Marcel
Old 6/13/08, 8:20 PM
Marcel
You know, like Marcel Marceu. Bad joke.
I'm sorry
Will Decker, CMI
Old 6/13/08, 8:22 PM
Thanks Wil, joke accepted, ha. ha.
Marcel
Old 6/13/08, 8:23 PM
mnahrgang's Avatar
I'm sorry
I got it, but it was a bad joke.
Mark Nahrgang
www.HeyMark.info
Old 6/13/08, 8:33 PM
Michael Larson's Avatar
It was a terrible joke. But from a guy that wears an orange shirt, what else would you expect.
Never underestimate the difficulty of changing false beliefs by facts.[/I] - Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
Old 6/13/08, 8:36 PM
Mike, you have a point there.
Marcel
Poly being applied to Basement walls dvalley Interior Inspections 40 11/24/09 10:49 PM
Unsuitable fill dirt causing foundation to crack, suit says ccurrins Structural Inspections 13 3/25/08 6:26 AM
Foundation Crack Question thejnicki Structural Inspections 3 9/27/06 11:37 PM
