Aaron lore is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have a 17 year old furnace that cycles on and off every 5 min. or so. I have been told to leave blower running so I don't ruin blower, but is there any adjustments that I can make to stop this problem. Or is this a problem?
Could be several things causing this. The only one you should consider are checking to make sure your air filter is clean. There can also be problems with the burner lighting system or blower blower control but these are well beyond the expertise of the typical home owner. Be safe and and contact a HVAC service technician. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
is it the burner coming on off every 5 min or the fan? if it is the fan the furnace needs a cleaning the heat exchanger may be full of soot, if it the burner it may be the high limit switch cutting in and out
hvac-talk.com Pro's all over the place on that board that can tell you specifics.
Bill Boerner STL Home Inspection Services LLCServing St. Louis/Surrounding (314) 805-2137 office@stlhomeinspector.com http://www.stlhomeinspector.com Residential, Commercial, Radon, Termite, Lateral Sewer Scopes |
Also can be the thermostat.
It takes more than symptoms to tell you what's wrong with a gas heater. Call for service. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
It's short cycling. Many possible reasons. Call your local heating and cooling professional to determine the problem and repair options.
Three problems you never ignore;
1 - your mother-in-law 2 - the brakes on your car 3 - your furnace Call for service YESTERDAY ! |
Hey, George. I'm perplexed. So you do not ignore your mother-in-law, but you can ignore your spouse? Hmmmmmmmmmmm. LOL
1 - When she was alive - AGREE 2 - AGREE 3 - AGREE - Serviced this past weekend Aaron, Recommend calling your local trusted HVAC contractor . . . several possibilities . . . call now. Mike Chris, Santa Clara, Utah
NACHI: #05051385 HouseNspect@gmail.com www.housenspect.com activerain "A man's home is his castle . . . until the queen arrives." |
What "short-cycles" the burner or the blower? If the burner short cycles it mayy be a clogged filter, causing the "high-limit" control to turn off the burner.
John Dee is a non-member guest and is in no way affiliated with InterNACHI or its members.
Replace the " Fan Switch". aka ;cam stat, fan limit combo , etc;
it is weakened by the helix bi metal that over a long period of time weakens. to stop it from short cycling , it would be wise to seek a professional, They have a free directory and resources that are local nationally to everyone. also , you can ask any question and get life time support or help as long as the site is open and you are a member. HvacrTalk.com Last edited by John Dee; 2/2/09 at 4:18 PM.. |
Good possibility that it is the thermostat. There is an adjustment for what is called anticipation. If that is off or not working, it will cause the furnace to short cycle.
Robert Sole, CMI 407-637-7288 Florida license numbers HI 169 and MRSA 92 Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties. RobertSole@REMinspections.com Check out my blog orlandohomeinspections.info/ REMinspections.com OrlandoHomeInspector.net |
| Uhm, new furnace will be cooking my A-coil ??? | Hvac Man123 | Inspecting HVAC Systems | 9 | 10/24/08 8:51 AM |
| Direct vent oil furnace question | Bart Connors | Inspecting HVAC Systems | 6 | 7/29/08 7:55 AM |
| Furnace Problem Comments Welcome | rfrost | Inspecting HVAC Systems | 28 | 10/21/07 6:26 PM |
| question on wireing furnace, legal or not | Bill Hathaway | Electrical Inspections | 26 | 1/19/07 10:36 PM |
