Old 11/1/08, 4:27 PM
Roy Drangstveit's Avatar
Roy Drangstveit Roy Drangstveit is offline
Default Garage firewall
I inspected a home today that has a metal wood burning fireplace installed in the living room in the common wall of the living room and the garage. The garage side of the fireplace is bare sheetmetal not covered with type X sheetrock.
Is this considered an interuption of the garage firewall?
Can it be left as is, or should it be wrapped in fire rated rock?
Can anyone help?
Roy Drangstveit
Old 11/1/08, 5:17 PM
Default Re: Garage firewall
Can anyone help?
Roy Drangstveit
Roy, if you mean the metal of the back of a zero clearance fireplace is exposed with open studs/framing, then, that would be a breach of the fire separation wall.
Otherwise, pictures would be helpful.
Larry Kage, CMI
231 929 3525
Plywood/sheetrock garage firewall Al Barb Interior Inspections 4 2/16/07 12:47 AM
Giant hole in the garage firewall for HVAC VENTS mpeterson Structural Inspections 14 2/3/07 6:54 AM
Garage Firewall jfunderburk Structural Inspections 19 4/9/06 8:23 PM
