Old 8/28/11, 10:52 PM
David A. Hill David A. Hill is offline
Default Garage firewall and storage cabinets
Hello all,
Just curious if any of you report storage cabinets attached to a garage firewall? The code is a little murky on this. (not that we are code enforcers)
Thanks, and I look forward to your replies.
Btw, I usually mention that combustible materials mounted to a garage firewall, adjacent to a living Space, is not recommended.
Dave
Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/29/11, 4:13 AM
Stephen W. Stanczyk's Avatar
Default Re: Garage firewall and storage cabinets
If the firewall is not damaged, I don't have a problem with attached cabinets or shelving. Of course it is quite impossible to see if the wall is damaged in back of any attached cabinets.
I see no reason to have any warning about wood shelving or cabinets on those walls. I think that is an over-reaction by quite a bit. JMHO.
Stephen Stanczyk
Old 8/29/11, 7:44 AM
Wayne B. Wilson's Avatar
Actually I know where he is going with this one, If it is directly fasten to the wall there could be a transfer of heat through the fasteners . I would not write it up because if it is that hot , In most cases the fire wall would only delay not prevent penetration .Good point however.
With what most people store on shelving in garages it is a wonder more disaster do not happen , 5 gallons of gas, fertilizer , Propane tanks , and lord only knows what other chemicals , Pool Supplies. Insecticide . It was great being a Fire fighter LOLOL
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 8/29/11, 10:25 AM
Jeffrey R. Pope's Avatar
Ditto...
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/29/11, 11:38 AM
Jeffrey R. Jonas's Avatar
Originally Posted by jpope View Post
Ditto...
Double Ditto!
Old 8/29/11, 3:17 PM
Thanks for the response guys!
I was reading the code on this, (which can be hard to get the point of the code, I didn't quote it here.) and it says combustible materials can't be anchored to the drywall in such a way as it could pull off the drywall (firewall) if the event of a fire. So, how do you know which storage cabinets are installed this way or not????
It was helpful reading the replies, it helped.
Thanks again! Be safe out there!
Dave
Firewall bdimasi California Inspectors 13 10/30/08 3:24 PM
