View Poll Results: How do you check a garbage disposal?
I don't! 1 1.96%
I run the rest of my lunch through it. 1 1.96%
I turn it on and listen. 49 96.08%
I put something in it from the seller. 0 0%
Multiple Choice Poll. Voters: 51. You may not vote on this poll
Old 12/5/08, 9:35 PM
Andrew Cox Andrew Cox is offline
Default Garbage disposal
How do you normally check a garbage disposal? I had one a couple of months ago - turned it on, but it was empty, sounded fine. On final walk-through, the disposal didn't work.
The realtor called a plumber-he said it was rusted and couldn't have worked.
It's being replaced under the AHW warranty.
So, how do you check them, or do you check them?
I got this to clean my disposer at home. I'm thinking of using these to check the disposal during my next inspection. It'll clean the unit and I will know it's working...
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Old 12/5/08, 10:11 PM
Bob Elliott's Avatar
Default Re: Garbage disposal
Just check the motor sounds ok and check the blades if you can remember to do so.
Old 12/5/08, 11:21 PM
Chuck Evans's Avatar
Sometimes in a vacant house the plate and chamber will rust up and seize. If you can turn it to free it up they will often work fine.
You can run a couple handfulls of ice cubes through to break-up clean off the some of the rust. But if it sits unused for a long time it will seize again. I prefer the disposers with the stainless plates and chambers, not just the rams, for this reason.
As far as the plumber goes: unless he was there with you on the day of the inspection, he has no basis upon which to make such a statement. If he made such a comment around me, i would have told him to please tell us all the exact date that it did stop working since he seems to be clairvoyant.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 12/5/08, 11:31 PM
That was essentially my reply - and it was dropped. I would like to have a better way to test it, that's why I want to have something to drop in that wouldn't be bad to leave, in case the thing doesn't work.
Andy Cox
Kissimmee, FL
Old 12/5/08, 11:33 PM
James F. McKee's Avatar
andrew if You turn it on ...it runs and it sounds ok that is about as much as You can do...jmo....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 12/6/08, 1:28 AM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
I run it and look inside to see how it looks. If it is heavily rusted I comment that it may be nearing the end of it's life.
Old 12/6/08, 4:26 AM
W. Michael Chris's Avatar
W. Michael Chris W. Michael Chris is offline
I try and put my hand down in and spin the impellers, or use a long screwdriver, that way I know whether the impellers rotate or not . . . I'm not at my normal computer or I'd post a cut away to place in my report . . . will try and get back with the photo/illustration I use.
Mike Chris, Santa Clara, Utah
NACHI: #05051385
HouseNspect@gmail.com
www.housenspect.com
activerain
"A man's home is his castle . . . until the queen arrives."
Old 12/6/08, 4:33 AM
Found photo/illustration on laptop . . . hope this helps.
NACHI: #05051385
www.housenspect.com
activerain
Old 12/6/08, 5:38 AM
Ice cubes
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 12/6/08, 7:08 AM
Originally Posted by bgraham View Post
Ice cubes
Do you bring them with you in a vacant house? . . . or one with frig missing in action?
NACHI: #05051385
www.housenspect.com
activerain
Old 12/6/08, 8:35 AM
Brian E. Kelly's Avatar
I wrote up a frozen dispsoal once and a realtor jacked around with it and got it working during the inspection so I changed my report and said it worked. About three weeks later the buyer calls and says his disposal did not work, I reminded him that I told him that, at the time of the inspection, but that his realtor got it working. Since that time if anyone "fixes" any thing while I am there I note what was fixed and by who.
No good deed goes unpunished.
Old 12/6/08, 9:13 AM
David A. Andersen's Avatar
Home Inspection is not a "performance inspection". Check your SOP. Some do not even require that you look at appliances...
HI does not require testing of capacity or analysis of performance.
Throw in some ice, watch it break, get out your wallet!
The GD is not designed for high speed ice crushing. And how many "rusted" ones are out there in poor shape?
Oh, and the GD is not prone to misuse and abuse by the homeowner? How many years does your inspection warrant it?
Thought so.......
BPI# 5015804
Old 12/6/08, 9:20 AM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
I look in the drain area to see if there is anything in there before I turn on the switch. Look for any heavy deposits that might damage the unit if I turn it on. Run water down the drain. Then turn the switch and listen for any irregular noises. Turn the switch off and check that it still rotates for a second or two after power has been turned off. Usually will indicate a worn bearing if it stop too soon. You should also be able to see the blades pivoting at when it slows down. After it stops, AI turn off the water and check for leaks underneath the sink, especially at the sink attachment flange.
When I write something up, I always point out that although appliances may be functioning at the time of inspection, they have moving parts that can wear or break down at any given time and that the inspection process does not determine the life expectancy of any appliance but merely documents the current condition at the time of inspection. Document whatever you or anyone else has to do in order to get tricky appliances to work in your report. Also, document anything realtors decide to say or comment about during the course of YOUR inspection process.
Old 12/6/08, 9:38 AM
If I turn anything on and it does not come on in the first attempt, I always write it up.
"The device did not operate on the initial attempt. The device began functioning after repeated testing. Recommend replacement. "
This often happens to me with GFCI resets.
If it didn't work once, it will likely fail again in the near future.
This is one time you can truly say the device is likely at the end of it's expected life.
BPI# 5015804
Old 12/6/08, 10:44 AM
If something doesn't work when I inspect it, it goes into the report.
If someone "fixes" something while I am still at the inspection, typically, my report does not change. They can later say that they fixed it if they want.
I've changed my report when I realized that I wasn't operating something properly though.
Disposals I turn on the water with it and listen.
Larry Kage, CMI
231 929 3525
Garbage Disposal GFCI ?? sbenson Electrical Inspections 5 8/5/08 12:14 AM
Disposal . . . want to share wchris1 Plumbing Inspections 3 3/28/07 12:33 AM
Garbage Disposal Trap? bkelly2 Plumbing Inspections 1 1/17/07 2:54 AM
Removing Garbage Disopal... Here2Learn Plumbing Inspections 7 11/24/06 3:36 PM
Garbage dispoal plug JohnH515 Plumbing Inspections 12 3/1/06 9:54 AM
