Old 3/11/09, 5:12 PM
bclark's Avatar
bclark bclark is offline
Default Gas logs/vented or not
I inspected a house today and I come to the fireplace a metal prefab with gas logs. It has a flue so I assume these are vented logs. I have always heard that these logs will collect black soot from the natural gas; However I have never seen it before until today. Does the gas line need to be cleaned or replaced.
Thanks Billy,
President, CORE Home Inspections, LLC
"Committed to Excellence"
Visit: www.corehomeinspections.com
Old 3/11/09, 6:21 PM
Bob Elliott's Avatar
Default Re: Gas logs/vented or not
They may even be getting a bad air mix.
That looks very bad.
Couldthey be burning stuff on top?
Maybe they have kids playing around.
Old 3/11/09, 7:45 PM
kpierce's Avatar
kpierce kpierce is offline
Please Note: kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does not look good. Definitely not operating as intended.
Old 3/11/09, 7:52 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Definitely vented. The black soot build-up indicates that Gas Fire logs are not arranged or positioned according to manufacturer's specs. If not positioned correctly, carbon monoxide can be produced. Also, be sure to check that damper lid has a clamp to keep it forced open.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 3/12/09, 6:59 AM
David Sorge's Avatar
David Sorge David Sorge is offline
That looks like a standard wood burning insert style fireplace with a gas log lighter installed. The log lighter is designed to light wood logs. It looks like someone took some fake logs from a gas-fired ambience fireplace and placed them on the grate. If you do that the logs will turn black since the flame is not regulated like it would be in a gas appliance.
If what I'm seeing is correct (can't be certain just from a photo), there is nothing wrong here. (other than a cheap homeowner)
David Sorge (USN Retired)
FL License HI142
Infrared Certified Thermographer
Inspect-It 1st of Northeast Florida
Serving Jacksonville and surrounding communities
904-484-4847
dsorge@inspectit1st.com
http://www.dsorgeinspects.com
http://www.linkedin.com/profile?view...US&trk=tab_pro
We see RED...InfraRED
When we see RED...
You see $GREEN$
Ask us how?
