During my inspection today, I came about a a room in which the water heater and the furnace was. There was also a gas manifold on the opposit from the furnace. There was a gas smell in that room but my TIF 8800 didn't detect anything around the units, manifold or in the air .
Where there is a Will there is a Way! Will Misegades TREC# 10465 RedFish Home Inspections www.redfishinspections.com |
| Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
If there was a gas odor then there must have been a gas leak. Have them call the gas company
Where did you eat lunch?
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Quit worrying about this... Send the realtor in with lighted match.
Seriously, call the gas company and quit thinking about who, what, where, etc |
I got yelled at for calling in the gas company once when I could not locate a leak while working for Sears (before detectors).
Turned out to be defective elbows from China that had pinhole leaks. |
Smelled Gas in Furnace area Reported this to gas company . and move on ... Roy |
It is being sucked in at the basement level or the bottom of the home and is probably at the union outside. I found two so far just as the weather got cold. The reason is the cold temperature changes, but that does not apply where you are. You will not detect it with your tiff 8800 because you are not close enough to the source.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
I was called into a utility room by a concerned client where there was a relatively strong odor of natural gas. The room housed the water heater and laundry facilities, and was directly adjacent to the kitchen where the odor was also present, but much less noticeable.
The house was all electric. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I did a house where every fitting on the water heater set my Tiff off. gas company was called to repair and they couldn't find any of those leaks. there were a couple others that they were able to find, one at the meter and one at the furnace.
Did a energy audit in Tonganoxie, Kansas last August, and was getting some whifs of gas odor when checking gas lines for leakage, but yet the TIF 8800 wasn't picking it up. After looking around found a capped off Natural Gas line behind the electric clothes dryer that had a very slight leak, the old gas line (that had served a gas clothes dryer in the past) had a branch valvethat was in the open position, so turned it to the closed position and had the client get it serviced... It has been my experience that the TIF doesn't pick up gas leakage unless in very close proximity to the line, valve or a pipe junction...
Patrick Carter BPI Certified Professional Building Analyst Missouri Certified Energy Auditor Kansas Certified Energy Auditor Call (816) 510-3234
mercaptan( the smell added to orderless natural gas) is detectable by the human nose in extremely small ppm.
It is very difficult to find very small gas leaks that are far below any hazardous levels. Your nose is much more sensitive than the Tiff. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
| Underground plumbing leak | jhaynes | Thermal Imaging, Infrared Cameras & Energy Audits | 10 | 7/31/09 1:34 PM |
| Leak in bay window with copper roof | hmiles | Exterior Inspections | 19 | 11/22/08 8:37 AM |
| Leak in water line outside ... what is ... | Bill Featherstone | Plumbing Inspections | 6 | 1/12/08 8:17 PM |
