Old 2/24/09, 7:56 PM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via MSN to jcampbell Send a message via Yahoo to jcampbell
Default Got Asbestos? Ya think?
While I am not confirming this for the buyers... this estate sale had "asbestos-like qualities" to say the least...
  • Exterior wall on the porch (vinyl outside)
  • Insulation in the basement
  • Flooring in the basement (9x9)
  • Other older flooring throughout upstairs
the folks are getting a good deal per the agent but there insulation and flooring need attention.
DISCLOSURE STATED: ASBESTOS: X Unknown
got-asbestos-ya-think-147_0288.jpg   got-asbestos-ya-think-147_0342.jpg   got-asbestos-ya-think-147_0237.jpg   got-asbestos-ya-think-147_0425.jpg
Jeff Campbell
Campbell Property Inspections
http://www.maineshomeinspector.com
Pittston, Maine
NACHI04013010
Old 2/24/09, 8:20 PM
Brian E. Kelly's Avatar
Default Re: Got Asbestos? Ya think?
That third exterior picture looks to be asbestos tiles to me. My parents house is sided with it, built in the early 40's. Great material.
Old 2/24/09, 8:22 PM
jhenderson1 jhenderson1 is offline
Nice, appears to be airocell pipe insulation, two different colors of VAT (vinyl asbestos tile)-actually-this appear to be 8x8 (used in the 1950's) and transite siding. This is all presumed, pending analysis by Polarized Light Microscopy in accordance with EPA protocol
john j. henderson, PG, CIAQP
HR Associates, LLC
Old 2/24/09, 9:23 PM
John R. Fordyce's Avatar
John R. Fordyce John R. Fordyce is offline
This looks like asbestos to me as well. I see alot of this in my area. Alot of the old mining towns used this kind of siding.
John R Fordyce
Safe-Buy Home Inspection
Keystone Inspection & Testing Services
NACHI #06051992
<< Home Inspector Marketing Map - Marketing Madness for Home Inspectors >>
Old 2/24/09, 10:45 PM
George A. H. Luck's Avatar
George A. H. Luck George A. H. Luck is offline
We have a lot of that siding up here too. Mainly on what we call "war-time" housing built 1945 - 50 ( although the war was largely over by then except, apparently here!!) Great siding in terms of wear resistance. Scares the hell out of purchasers though.
Old 2/24/09, 10:58 PM
hlowe's Avatar
hlowe hlowe is offline
Hey George!
You're right on. That is definitely Johns-Manville siding, in the third photo. We do see lots of that up here.
Harold J. Lowe C.M.I., C.C.I.
Eagle-Eye Healthy Home Inspections
Sharondale Academy of Home Inspections
www.healthyinspections.com
harold@cannachi.org
haroldjlowe@hotmail.com
home-905-576-4337
cell-416-912-0852
CanNachi Director of Education
Certified Infrared Thermographer
Pro-lab Certified Mould Specialist
IAC2 Certified Indoor Air-quality Consultant
Certified Commercial Inspector
Toronto/Durham/Kawarthas
Proud InterNachi Member # 06091197
Old 2/24/09, 11:10 PM
the fourth photo is actually sheet flooring... not individual tiles...
the only thing missing was an asbestos heat shield....
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 2/25/09, 1:14 AM
Tim Spargo's Avatar
# 3 is asbestos siding in appearance, 9 x 9's depending on circa are suspect as well. Those old VCT's are problematic, at times even if the tile is free of asbestos, the adhesive will contain...
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 2/25/09, 8:19 AM
Frank M. Carrio, CMI's Avatar
Frank M. Carrio, CMI Frank M. Carrio, CMI is offline
ESOP Committee Member
I think that you are correct. The old 9x9 tile is called VAT which stands for " Vinyl Asbestos Tile".
If any of the tile were loose you can look at the adhesive and if it is black it is the old "cut back" adhesive and it certainly does contain asbestos.
One important thing to note is if the VAT, the piping insulation, and the exterior siding are not broken then they are considered to be "safe".
  • But..... Although "safe" it certainly should be mentioned in your report!
When the above-mentioned products are broken or chipped then they can become "airborne" and that is when the problems arise.
Signed, Frank Carrio, CMI
Certified Master Inspector & Consultant
Certified, WDI Inspector
Founder & Current President, New Hampshire State Chapter NACHI
NACHI, State Representative for Legislative Affairs
Retired: ICC Certified Member
Retired: Code Compliance Inspector.
Retired: ASTM Committee Member
New Hampshire License #0096
Old 2/25/09, 8:26 AM
absolutely Frank...
the siding is in great shape and possibly under the remaining vinyl siding... the insulation appears in good condition and could be encapsulated to ensure it does not become friable... the tiles are loose in many areas (i did not look at the adhesive, but good to know)...
I am mentioning it all... the client could not attend but we are doing a walk through on Friday when she flies in... (contractors in tow...)
Generally we come across one or the other... this home had a little of everything in it... it was an asbestos training home....
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 2/25/09, 10:08 AM
David P. Valley's Avatar
absolutely Frank...
Jeff,
I run into those same asbestos materials quite a bit down here. Generally, asbestos-containing materials do not have to be removed from any residential property. In fact, asbestos-containing material does not have to be removed from any residential structures unless it will be disturbed during renovations or demolition activities. As long as the asbestos-containing material is in good condition, in tact and will not be disturbed; it does not pose a significant health risk. It's when asbestos is exposed and friable, flaking or crumbling, and that it's likely to become airborne, is when I recommend encapsulation or professional removal by properly licensed personnel.
Removal should never be attempted by the homeowner. This action requires special equipment and detailed training which would generally be too expensive and time-consuming for a homeowner to acquire for a one-time job. Removal is also the last choice among alternatives because it poses the most risk of fiber release if not done properly.
Even though Asbestos appears to be in good shape in this particular home, it's always noted.
Old 2/25/09, 4:47 PM
Peter Doane's Avatar
Jeff,
Q: It sounds like you think they should have check YES on the disclosure statement... no?
We all know, that you can't confirm material makeup, unless suspect materials are tested. i.e. as you stated "asbestos-like qualities" isn't it only right to give the seller the same liability exclusion as you? It is in fact a non deceiving answer: "unknown" until testing confirms presence... Just playing devils advocate. But thats why we are in the business. Nice pictures.
Peter Doane
NACHI ID# 05120681
Old 2/25/09, 6:44 PM
mbartels's Avatar
mbartels mbartels is offline
Please Note: mbartels is a non-member guest and is in no way affiliated with InterNACHI or its members.
It looks like my first home. I lived in a Levitt home in Bowie, MD. The same as the more famous Levitt towns you may have heard about in NY and PA. My house had Asbestos floor tile with asbestos mastic, asbestos cement siding, aluminum wiring, lead paint and the below grade ducts that ran through the slab. (These would fill with water on some lots.) I had also heard that there was asbestos in the drywall mud but I never confirmed that one.
I lived in and worked on these houses for almost 30 years. Its amazing that I'm still alive.
People there tended not to freak out about it because every house, and it was thousands of them, all had the same materials. The floors were carpeted over and if people wanted new siding they would just vinyl over the asbestos. The housing stock in the area was also generally older so people were more accustomed to these things.
The sad thing is that I actually miss these older houses. The area I live in now has some of the crappiest housing stock I have ever seen. All these homes have moldy crawlspaces, cracked foundations, bouncy joists, furnaces shoehorned into 18 inch high crawlspaces, hardboard siding, and PB pipes. There is apparently been no oversight in the building process since 1985.
I wonder what we will talk about 20 years from now on homes built today.
Remember when we used plastic for water pipes! Oh the horror...
Old 2/28/09, 7:52 AM
nwagner's Avatar
nwagner nwagner is offline
An excellent real life example to highlight the need for a home inspection. Most folks don't have a clue what asbestos is, why its harmful and what products likely contain it.
Old 2/28/09, 11:28 AM
Gary Oleski Gary Oleski is offline
Asbestos containting products and materials. www.asbestos.com/products/
Gary Oleski Home Inspections
Home Inspections Connecticut
Connecticut . 06610
NACHI04012833
CT#HOI.341
C M I
Asbestos jmckenna1 Miscellaneous Discussion for Inspectors 0 1/26/07 11:11 PM
Asbestos jmckenna1 Miscellaneous Discussion for Inspectors 0 1/26/07 11:09 PM
Asbestos Still Legal, Dates of Bans Stephen Masek Ancillary Inspection Services & Additional Topics 8 1/17/07 8:26 PM
Is this a competent asbestos removal job? Is our basement now a biohazard? David Paterson Ancillary Inspection Services & Additional Topics 5 1/16/07 7:16 PM
Mould v. Asbestos Caoimhín P. Connell Ancillary Inspection Services & Additional Topics 30 1/15/07 10:35 PM
