| Find an InterNACHI certified Illinois Home Inspector (and anywhere else in North America) |
dbolduc is a non-member guest and is in no way affiliated with InterNACHI or its members.
The bullet list under 'Problems associated with....' needs caps to start each item to keep the format the same as above.
Additional information on the advantages and disadvantages of the two types of drying lumber;
Kiln Drying Rate of drying can be controlled by varying heat and relative humidity. Controlling drying rates minimizes drying defects in lumber. Lumber can be dried to 8% MC, or less, for use in interior applications. Staining of lumber can be controlled by using heat and air flow to rapidly dry the surface of boards. Drying time is norma lly les s than one month for common northeast species. Lumber must be trucked to and from the kiln. There is an out-of pocket cost associate d with kiln drying. Air Drying Rate of drying is subject to the weather. It is not possible to dry lumber to less than about 15%MC, wit hout further drying in a he ated building. Warm, humid conditions with little air movement can promote some types of stain. Drying can take several months under ideal conditions. Lumber can be dried on-site, in any area which receives good air-flow. Air drying can be a low cost alternative. This last method is what is typically used for framing lumber. It will also normally bear the stamp S-Dry No. 2 Stud grade LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I would try to list other home issue results from using green wood; squeaking floors, trim gaps, etc.
That would be a great addition to the article, and the photo was perfect. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Crimea River here, Editor Extraordinaire...I'm afraid Microsoft has done the struggling literate world a great injustice with the MS Word program's default setting of capping words merely because they appear first in a new line, whether in bulleted or numbered lists. It may look pretty, uniform, official, etc., but the rule for excruciatingly correct punctuation (my wheelhouse) is this: Do not cap the first letter of the first word if it is not the first word of a complete sentence. To wit: I like coffee and I like tea, but I don't like:
Note, too, the use of the much-abused semi-colon [;], which is properly used (instead of the comma) after a colon [:] to connect a series of related ideas. Now, this would be correct: The following are examples of problems encountered with roof inspections:
You must change your default settings so that Word stops automatically capping the first word of each new line. Some people won't do this because they don't really care, but here at InterNACHI, we're all about literacy, as well as accuracy... Cheers, Kate
Go get him, Kate. At InterNACHI we don't screw around.
Mark - I'll take a look at that thread and have a powow with Kenton, we'll see what comes of it. cheers Researcher and Technical Writer, InterNACHI |
Don't blame you! She's a good one to have around!
| Please proof this new article on Fire Extinguisher Maintenance and Inspection. | gromicko | Miscellaneous Discussion for Inspectors | 7 | 4/27/09 6:15 AM |
| Please proof this new article on inspecting septic systems. | gromicko | Ancillary Inspection Services & Additional Topics | 4 | 4/20/09 10:31 PM |
| Roy the proof you asked for | wdevries | Canadian Inspectors | 55 | 7/8/08 10:30 AM |
| Are electricians supposed to use these tools as per 70E? | jtedesco1 | Electrical Inspections | 27 | 12/15/07 3:40 PM |
| Treated Lumber Changes | jmckenna1 | General Inspection Discussion | 2 | 8/10/06 7:57 AM |
