Old 9/9/10, 7:19 PM
Bruce A. King's Avatar
Default Guess what is wrong
Guess what is wrong...........
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/9/10, 9:18 PM
Brian E. Kelly's Avatar
Default Re: Guess what is wrong
old attic hatch compressing insulation?
Old 9/9/10, 9:40 PM
nope, new house, not missing insulation or a leak.
704 301-3207
Old 9/9/10, 9:46 PM
Jeffrey R. Wicklander Jeffrey R. Wicklander is online now
Attic keyless fixture a little too low?
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 9/9/10, 9:58 PM
Kevin M. Leonard's Avatar
Kevin M. Leonard Kevin M. Leonard is offline
A lack of or inadequate attic ventilation.
Kevin M. Leonard
The Ohio Home Inspections Company
513-895-7700
937-283-5118
Old 9/9/10, 10:15 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Loose plenum/ductwork?
www.MauiHomeInspections.com
Old 9/9/10, 10:31 PM
Allan G. Berdahl, CMI Allan G. Berdahl, CMI is offline
Missing portion of vapor barrier?
Allan Berdahl
Aarlan Home Inspection Services
Calgary, Alberta
Bus: 403-808-5355
Cell: 403-803-4064
Fax: 403-204-8863
Email: aarlan@telus.net
Old 9/9/10, 11:34 PM
nope, A/C was running, hot day
A missing vapor barrier would not show up like that.
704 301-3207
Old 9/9/10, 11:37 PM
Tom Leahy Tom Leahy is offline
I like Jeffs light theory, but can't use that. So going with you sat your flashlight down when coming out and forgot it. Weak, but thats all I got.
Fort Worth Home Inspector
Dallas Home Inspector
Old 9/9/10, 11:40 PM
Spilled your coffee? Took a leak?
Jeff
Jeff Wicklander
is the HVAC Unit sitting there?
Old 9/9/10, 11:45 PM
No, the cooling mode was running, I had already inspected the attic and found this warm area while doing the IR scan. I made a note about low or missing insulation and was moving on through the house. Something made me go back and lower the stairs again, I went back up and saw the problem.
704 301-3207
Old 9/10/10, 12:01 AM
Kenneth Dolin's Avatar
Kenneth Dolin Kenneth Dolin is offline
and you are going to keep us in suspense for.......how long?
Ken Dolin
Kenco Home Inspections
WWW.Kenco.org
State of Florida Licensed Home Inspector HI 59
Old 9/10/10, 12:27 AM
Christopher Currins's Avatar
Has anyone answered correctly yet, or close?
Christopher Currins
Certified, Licensed
Old 9/10/10, 12:29 AM
This house had a 3.5 ton unit for the upper level with two return air registers visible but the third one was covered over with sheetrock. The hot attic air is being drawn into the duct some but mostly just trapped hot air inside the blocked off duct and up next to the ceiling.
Not all 3.5 ton units have three return registers, especially when the other two were not small in size.
704 301-3207
Guess Who and Win Mystery Prize. jmckenna1 Miscellaneous Discussion for Inspectors 15 4/4/08 6:22 PM
Free Books And Articles For Electrical jtedesco1 Electrical Inspections 14 1/6/08 6:45 PM
What's Wrong Here? jtedesco1 Electrical Inspections 10 12/9/07 9:36 PM
