Old 7/8/06, 3:38 PM
moliver moliver is offline
Default H2O heater and furnace wall mounted?
Yesterdays inspection. In the garage was a forced air furnace and gas water heater mounted on the wall in the garage. They sat in individual steel welded holders. Angle iron on the back of them with drilled holes and bolts into the studs of the wall separating the attached garage and house. The base (bottom) was at appx 4 ft. Making the tops 10 plus ft. Water heater cold shut off valve appx 12 ft high. Bottom of forced air furnace not able to have return at that point (so no filter) Hole cut out on back of unit for return air from duct penetrating firewall (not sure of gauge of ducting) insulated. Permits,TPR discharge aside. Comments on this application please: ie weight being carried by studs, height for service replacement etc. Return air back of furnace. First time seeing this.
Thanks NACHI
Mike
Old 7/9/06, 8:31 AM
Russel Ray's Avatar
Default Re: H2O heater and furnace wall mounted?
I commented for you, Mike, in the HVAC thread.
Martin Floor Furnace, Hunter space heater. mmasney Inspecting HVAC Systems 0 8/20/07 2:53 PM
Exhaust fan in room with gas water heater and furnace jweinberg Inspecting HVAC Systems 7 2/18/06 2:23 PM
