Excuse me as this simple home inspection has fried my brain and body.
Was told this home was a slab, tuned out it had a crawl. Seemed like a simple enough inspection. The vinyl siding was installed by an unqualified professional at lets say this area needed to be replaced. House was a one car attached and then an addition was added, so they turned the one car into living space and then added a 2 1/2 car garage. On the outside I noticed the CMU were displaced and the mortar was cracked with large gaps. Then I noticed what looked like a crawl space vent screen. So I am thinking crawl. Go into home and the floor registers are sealed and screwed in. Another sign of a crawl. There was no visible access. Buyers agent calls and the access is under the dishwasher. They state it is an uncovered dirt floor and there is a sump in the crawl. So am walking from laundry to original home and can feel the temp differance. Exterior has huge ice dams so I knew there was an insulation or ventilation issue. Go in attic, and was a mess. Wiring all over, vermin damage, insulation was damaged, missing, inadequate. HVAC in an unconditioned area, but due to it being old and inifficient, attic was like a suana. Most ducts uninsulated, not supported and around here should be in the floor. Outside every downspout was dumping next to the house and below ground drainage was diverted. I wonder how the sump is set up in the crawl. I bet it is a wet mess. Just glad I did not overlook this being a crawl or I would of been in trouble. Electrical looked updated but all the open grounds told me other wise. The electrical branch circuits were also messed up. They also had the water meter off and the water was on, so not sure how long they have been getting free water. Just thought I would type as this simple home needs some work. |
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Just another day in paradise, right? Right!
Here are a couple pics of the siding penetrations. Holes all over, evry penetration F uped, what is building paper, clearance from ground.
Just doing my job. I think they thought this had a cooling system. But there was none.
Dave I love the "Free" water part. I had one of those a few months ago and the seller was like "what do you mean"..LOL hahaha he new exactly what was going on, He did it..
Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
Oh how I hate vinyl siding. Glorified plastic coating, but guaranteed for life!!
Duke Griffin EcoVision LLC Home Inspections in Estes Park, CO |
David,
You know you'll get a call when they're moving in asking how to light the pilot light or something like that... you'll be thinking "Really?" |
