Old 12/27/10, 5:28 PM
Jeff Manders Jeff Manders is offline
Default Handling Painted Shut Scuttles
Just curious how everyone handles attic scuttles that are painted shut?
All attic accesses I've ever encountered in my two plus years in the biz have been accessable. However, I'm inspecting a fairly new home this week and I might encounter this. With 2+ feet of snow on many roofs it can be difficult to identify plumbing vents, attic ventilation ect.. from the outside. So it's pretty important to able to take a look up there.
I'm thinking that I either have the current owner crack that thing open before I get there. Or have him/her sign something stating that it is ok for me to do this, and I'm not responsible for any damage associated with that. Does anyone use an agreement like this?
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/27/10, 5:59 PM
mnahrgang's Avatar
Default Re: Handling Painted Shut Scuttles
Same as a painted shut electrical panel... utility knife.
Mark Nahrgang
www.HeyMark.info
Old 12/27/10, 6:07 PM
Jeff Merritt Jeff Merritt is offline
What Mark said, and a small drop cloth on the floor.
Old 12/27/10, 7:15 PM
Peter C. Russell's Avatar
Hyde makes a nice 4'' drywall knife with a tapered end that is perfect for anything painted shut.
Russell Inspection Services
New Hampshire state license # 57
Level I Thermographer, ITC
Certified Building Science Thermographer, ITC
Certified Building Analyst, BPI
Certified Commercial Inspector, ITA
Certified Septic Evaluator, GSDI #148
www.newenglandthermalimaging.com
www.russellinspectionservices.com
www.nhsepticinspection.com
Old 12/27/10, 7:25 PM
rsmith24 rsmith24 is offline
What about if they are cover with trim?
INSPECTIONLOGOS.COM
"I can keep explaining it for you, but I can't understand it for you".
Nick G.
Monroe Home Inspection
Old 12/27/10, 7:32 PM
It will work on that too
Old 12/27/10, 7:41 PM
Curtis M. Vilt's Avatar
Curtis M. Vilt Curtis M. Vilt is offline
Robert, I just did one last month with the panel trimmed over and I did not remove the trim as I see that as invasive and reported what I saw. Maybe I am not aggressive enough but I already received a referral from that client.
Old 12/27/10, 8:16 PM
John Martino John Martino is offline
I do try to open them. I have come across several along the way and they usually open with a little effort. Work around the perimiter with a stiff blade. I use the one on my leatherman, that works well. Sometimes you can give it a quick tap with your fist that sometimes can break the seal. Before you do any of this you should get permission from the seller. They are usually ok and understand that I need accress to the attic space.
New Jersey home inspections
New Jersey Home inspectors
Old 12/27/10, 8:20 PM
mnahrgang's Avatar
exactly... Write up as inaccessible due to finishing.
Mark Nahrgang
www.HeyMark.info
Old 12/27/10, 8:29 PM
You break / You buy / We don't break.
If painted shut ... Its NOT accessible by US.
Somebody else opens it, we'll look at the area BUT we will NOT be the wrecking crew.
Old 12/27/10, 8:44 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
What force is used? So NO tools can be used to attempt to open it?
Like others I disagree and would use a utility knife or other tool made of the purpose to attempt access. I find it very embarrassing if I told a buyer the attic was not accessible and he takes 30 seconds to get it open.
Thats just me...do as you see fit.
I know, I know, its beyond the SOP and once again I view the SOP as CODE for contractors. THE MINIMUM STANDARD.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 12/27/10, 8:45 PM
Roy D. Cooke, Sr's Avatar
No my job , If I can not get it open with No damage then I do not open .
Old 12/27/10, 9:18 PM
This is where letting the listing agent or seller what to expect and tell them to have all hatches to crawls and attic spaces cleared and open for inspection. and any other access panels that may be hiding from view, I also ask (around here in new condos) to remover the expensive paintings that are covering the electric panels. Takes 5- min and saves a lot of hassle most of the time.
Old 12/27/10, 10:32 PM
John Harrison's Avatar
John Harrison John Harrison is offline
Just had one today that was caulked closed. I left it the way I found it no access to the attic.
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas
Active Rain Member
Old 12/28/10, 12:47 AM
Christian F. Mettel Christian F. Mettel is offline
I have run into the situation a few times. If I cannot open the hatch without damage(I do use the utility knife on painted shut hatches), then I disclaim the attic.
Christian Mettel
Certified Home Inspector
Aurora, Ontario
289-221-4744
iNachi ID#06022187
www.buildingdetective.ca
Aurora Home Inspection
Gas shut off valve Laura Line Plumbing Inspections 7 1/26/10 1:04 PM
Shut off valves required? jcahill Plumbing Inspections 11 9/2/08 1:07 AM
2 Shut offs for exterior A/C dmacy Electrical Inspections 12 10/12/06 10:29 PM
Gas line is shut off but pilot light is burning... jweinberg Inspecting HVAC Systems 15 2/13/06 1:43 PM
