I did an inspection on a home and the garage has a header that is sagging and should be replaced. The seller plans to replace the header with a new header. The buyer claims that the only fix is to have the seller install new girder truss with valley and gables to make it work.
I am getting calls from both the seller and buyer and my suggestion is call a structural engineer. I do not have the answer and would like some input I feel that the buyer is asking for more than needs to be expected from the seller. I am surprised the seller has not just cancelled the transaction. |
| Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
You cant size the lumber for the span. only an engineer or architect can. If the seller would have done that before this came up, then he could have done anything he wanted to. how much do you think it sags if you ran a string from one side to the other?
LeRoy, this is just my opinion but I would just note your finding (the sagging header) take a few "Good" pictures and then recommend further evaluation by a licensed contractor or engineer and move on as you have done all you need to as the Home Inspector. There is no need for you to get to technically exhaustive as that just opens up unnecessary cans of worms for you.
Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
This wood be an easy fix for me, but I agree as said, note the problem and defer to a qualified Contractor to repair.
Let the client negotiate with the seller on the monetary values. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Marcel, that would be a sweet little job wouldn't it.
What do you think, double 9'' LVLs ? Russell Inspection Services New Hampshire state license # 57 Level I Thermographer, ITC Certified Building Science Thermographer, ITC Certified Building Analyst, BPI Certified Commercial Inspector, ITA Certified Septic Evaluator, GSDI #148 www.newenglandthermalimaging.com www.russellinspectionservices.com www.nhsepticinspection.com |
Wrong! The IRC has span tables that can be applied by a builder without the need of an architect or engineer as long as the dwelling is one-or-two family and under 3 stories.
"A state of war only serves as an excuse for domestic tyranny." ~ Alexander Solzhenitsyn Certified Master Inspector (2007) Member, International Assoc of Certified Home Inspectors (InterNACHI) Member, International Code Council (ICC) - Certified Residential Combination Inspector Square-One Inspection "Assurance begins here"
That would be more than adequate Pete for the roof load on what appears to be 8' doors.
And what is that other beam under the trusses? LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Joe is right, you can order what you need directly from the lumber yard.
Tell them the span and voila, they will order what you need for the roof or floor loads. LVL beam charts and lumber beam charts are also readily available to all contractors that can read them. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Almost looks like it was originally framed for larger doors??
Pete, look where that beam is. It is above that sloppy hanger closer set up. I brightened up the picture a bit.
Doubled up vertically and roof trusses above, so don't know why it is there. doesn't make any sense. They should have used that for the door header.
Nice job guys thanks for the input,
LeRoy, can you shed some light on that beam on what it's purpose was?
And Happy New Year to you also. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
The beam is to support the roof on the front of the garage and whne it gets full of snow it sags
But I can see that those are roof trusses above. Trusses don't sag, they fail.
Any other explaination? Curious as hell. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| A header in a recently constructed house | tpino | Interior Inspections | 8 | 9/15/10 4:21 PM |
| Window header trim flashing | jfrederick | Exterior Inspections | 0 | 6/24/10 8:29 AM |
| 2x4 engineered floor joists holding deck header | bking | Structural Inspections | 1 | 1/27/10 9:10 PM |
| Possibly Overloaded Garage Door Header | pdickerson | Structural Inspections | 25 | 8/3/08 2:26 AM |
