A local AHJ said that One supply duct opening at living room, (opposite wall from gas furnace) is adequate at supplying sufficient heat to All habitable rooms, including three bedrooms; Even with doors closed.
Christopher Currins Professional Home Inspections In Edwardsville, Glen Carbon, Fairview Heights, O'Fallon, Godfrey, and surrounding areas of Southern Illinois We Make It Safer |
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Obviously you know more than him.
Thought the door was sinking in the first shot for a second . |
I turned it up a little and within a few minutes 3 smoke alarms went off. Christopher Currins Professional Home Inspections In Edwardsville, Glen Carbon, Fairview Heights, O'Fallon, Godfrey, and surrounding areas of Southern Illinois We Make It Safer |
Time to update. |
Old, probably original, house built in the mid-40's. Manufacturer is "Winkler", Lebanon Indiana, serial # 2239.
Cameron Anderson Bachelor of Architecture, U of I, Urbana IL Illinois Licensed Inspector www.aaintegrityhomeinspection.com |
Were you writing up lack of heat sources in the rooms?
Juan Jimenez
A House on a Rock Home Inspections LLC God. Family. Home. 804-269-4321 Richmond Home Inspector Richmond Radon Testing Recommend Us! |
The AHJ is correct. The requirement for heat does not say that it has be be distributed via duct to each room. The heater has to be capable of heating every room to a minimum of 70 degrees, measured 36" above the base board. Simple as that.
Even if it's 90 degrees in the room where the heater is located, if the habitable spaces reach 70 degrees, it's compliant. Smoke detectors will often sound when a unit is fired-up for the first time of the season. The dust that has accumulated on the burner chambers will smoke. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
You crazy cal guys do not need heat and in some cases no need for privacy. Lol |
Hi Paul
Please explain why you agree with Jeff besides you both being in a warm weather state. Chris and I live in Illinois so do you think you can please explain for all of us the exact amount of air space required under a closed door for that 1940 furnace to push heated air into into a closed bedroom space and heat it to a required 70 degree temperature. First explain how return vents work and why they are used then tell us if it is OK to open a window in in -50 degree weather as we sometimes get that in Illinois ,how about you ? Back to subject bedrooms are required to have privacy so if the door must be open to heat the room is that OK ? Thanks and glad you see it my way now . P.S we do not surf here either .LOL |
Bob's exaggerating, but only a little. The coldest day ever recorded in Illinois was -38°F and it happened in 2009. So much for global warming in that location.
I really don't care what the construction standards might say, if a decent sized room(especially a bedroom) has no heat source, I call it out as a defect. It's too cold in this state to report it otherwise. Cameron Anderson Bachelor of Architecture, U of I, Urbana IL Illinois Licensed Inspector www.aaintegrityhomeinspection.com |
Who cares about any requirements, codes, or whatever? Common sense to me and that's how I'd inform my clients. Like Cameron stated, that's how I'd report it - No/minminal heat at such and such areas - improve/correct as needed. If they are good with it (living with a central furnace), then so be it. I won't be living there and don't care. Maybe they'll leave the doors open at night so they can hear each other saying, "Goodnight, John Boy, Goodnight Mary Ellen"......
Well, since the OP was inferring that the AHJ was "wrong" by stating that this is a compliant heat source, the thread was not about a "common sense" issue. The AHJ is correct according to construction standards and model codes.
That certainly doesn't stop us from making recommendations for "upgrades," but to call this a defect is wrong. Having the ability to heat a residence is a life/safety concern. Privacy is not. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| No heat source | ragaian | Miscellaneous Discussion for Inspectors | 3 | 8/10/11 10:53 PM |
| Radiant heating in ceilings | bleibgott | Ancillary Inspection Services & Additional Topics | 13 | 4/26/10 9:27 PM |
| More Moisture Discoveries | jpope | Interior Inspections | 30 | 8/16/07 1:54 AM |
| Heat source required in bathrooms | menser | Inspecting HVAC Systems | 7 | 7/13/06 12:57 PM |
