Old 12/17/10, 4:45 PM
Chris Macrina Chris Macrina is offline
Please Note: Chris Macrina is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default HELP
My girlfriend is looking to buy a house - today i went and viewed it and while in the attic i saw steel cables every 3 feet that ran across the floor boards and where attached to beams on each side. The house appears to be in good structural condition but seeing this is concerning???
Can anybody help me understand why this was up in the attic and is it a bandaid to a much larger problem.
thanks
chris
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/17/10, 5:49 PM
Kevin M. Leonard's Avatar
Kevin M. Leonard Kevin M. Leonard is offline
Default Re: HELP
thanks
chris
Is she getting a Home Inspection? If not, she should.
Kevin M. Leonard
The Ohio Home Inspections Company
513-895-7700
937-283-5118
Old 12/17/10, 5:59 PM
Christopher Currins's Avatar
Default Re: HELP
Tell your girlfriend to hire a reputable home inspector. He/she should be able to determine if your concerns or an issue.
Christopher Currins
Certified, Licensed
Old 12/17/10, 6:57 PM
Default Re: HELP
Thanks for the replies and yes she is getting an inspection. Just wondering if anyone has seen it.
I was told that the architect who designed the homes addition suggested they put them up.
Old 12/17/10, 7:52 PM
Chuck Evans's Avatar
Default Re: HELP
Try to obtain the plans and engineering review for the addition/modification. If they are unavailable consider having a structural engineer review this aspect of the home in addition to your home inspector.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 12/17/10, 8:29 PM
Frank M. Carrio, CMI's Avatar
Frank M. Carrio, CMI Frank M. Carrio, CMI is offline
ESOP Committee Member
Default Re: HELP
thanks
chris
I suggest that you contact Mass. inspector David Valley at;
978-683-4984
1-866-705-3100 (TOLL FREE)
http://www.masscertifiedhomeinspections.com/
Signed, Frank Carrio, CMI
Certified Master Inspector & Consultant
Certified, WDI Inspector
Founder & Current President, New Hampshire State Chapter NACHI
NACHI, State Representative for Legislative Affairs
Retired: ICC Certified Member
Retired: Code Compliance Inspector.
Retired: ASTM Committee Member
New Hampshire License #0096
Old 12/17/10, 9:58 PM
Bob Elliott's Avatar
Default Re: HELP
That does sound unusual and to bad there are no pictures.
In the old days they would do that to hold the outside walls together in case of fire.
Old 12/17/10, 10:46 PM
Banned
Default Re: HELP
[quote=belliott;722963]That does sound unusual and to bad there are no pictures.
In the old days they would do that to hold the outside walls together in case of fire. [/quote]
Never heard that before , Bob. I would assume that the cables were used as would be rafter ties or floor joists running side to side to prevent splaying of the house wall from the downward and outward action of the roof rafters.
Old 12/17/10, 11:23 PM
Default Re: HELP
They are called brick ties and the older buildings have them.
It was a response to the great Chicago fire of hmmmm guessing 1877.
They often get cut during rehab.
I will post a picture from one of my reports when I can dig it up but it is often found in old greystones and courtyard style buildings and placed closer to the middle than the attic.
Almost looks like a approx 12 inch piece of rebar hanging off the side walls when seen but hides in the subfloor areas.
Old 12/20/10, 7:33 AM
Robert W. Jude's Avatar
Robert W. Jude Robert W. Jude is online now
Default Re: HELP
or it was a repair because something was bowing/ sagging. is it possible the house has been moved?
Old 12/21/10, 12:07 AM
Scott May's Avatar
Scott May Scott May is offline
Send a message via Skype™ to smay
Default Re: HELP
Never have I seen cables in a house but might be method to their madness in an un- orthodox way. They cable limbs on trees and it works.
Definitely out of the ordinary.
Try not to become a man of success but rather to become a man of value!
WWW.eyespy-homeinspections.ca
Serving: Collingwood, Creemore, Dundalk, Durham, Flesherton, Hanover, Kincardine, Mansfield, Markdale, Meaford, Owen Sound, Port Elgin, Sauble Beach, Shelburne, Southampton, Stayner, Thornbury, Wasaga Beach and Wiarton.
Old 12/27/10, 4:36 PM
Walter E. Bancroft Walter E. Bancroft is offline
Default Re: HELP
Chris-- Is this a masonry structure? It is not unusual (at least in Wisconsin) to find such cables in older masonry homes. These were used to help keep the walls stabilized--especially if a fire should occur.
Old 12/27/10, 4:39 PM
Default Re: HELP
Sorry Bob---I guess you already answered that. I just didn't read down far enough.
Walt
Old 12/27/10, 6:35 PM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
Default Re: HELP
what chuck said...
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
