Old 3/6/11, 3:04 PM
John M. Acaron's Avatar
John M. Acaron John M. Acaron is offline
Question High end Wood doors inspection (rot). Litigation
I am quoting a job to fully inspect (assess the condition) wood doors (exterior) rotting. Looking for a source that will guide me to specifics regarding the inspection.
I have done similar work in the past (moisture meter, Hydroprobe, tapping, etc). However, any additional info will help. Large number of doors to be inspected (installed). Thanks!!
John M. Acaron, BSME, CMI
HOMEINSPECTORUSA, LLC
State of Florida Licensed Home Inspector
State of Florida Licensed Mold Assessor
BSME & TDME (Mechanical Engineer)
Certified Master Home Inspector
Certified Indoor Air Consultant
Office: 850-814-3889
FAX: 850-249-8997
SEMPER FI
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/6/11, 3:41 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
Default Re: High end Wood doors inspection (rot). Litigation
John. There should be an istallation guide for these doors somewhere. Although you cannot see the stuff behind the sceens, you can sure see if the proper screws, placement fo the screws and hardware and the seen its are present and installed according to manufacture recommendations.
I would also wait for a good florida rain and use thermal imaging as well as moisture meters. If there has been no rain the recent past, then thermal and moisture meters are useless unless you perform a "water test".
Hope this helps.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 3/6/11, 4:53 PM
Tim Spargo's Avatar
I've dealt with this co a number of times, maybe they can provide some info? http://www.aawdoorsinc.com/
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 3/6/11, 6:08 PM
Here is the scope of work:
1.Review all doors to identify how many doors are currently showing signs of wood rot.
2.Assess the possible reason why the doors are rotting in such a short period of time.
3. Provide a report to the owner of how many doors are rotting, reasons why they are rotting, and how many more doors you expect to rot in the future.
FAX: 850-249-8997
SEMPER FI
Old 3/6/11, 6:37 PM
Exterior wood doors exposed to the elements can provide a variety of problems.
Doors showing signs of rot indicate that water intrusion is occurring due to water infiltration at the threshold and or weather stripping if the door is in swing.
A lot of time with wood doors, they start absorbing moisture due to humidity on the interior and or the exterior due to a poor in the field finish.
Pre-finished exterior wood doors could have been planed at the edges due to swelling caused by humidity and never sealed properly thereafter.
Most factory finished doors do not have the bottom and tops sealed and always left in that condition which make them prone to water intrusion and with time, rot.
Most doors on the high end homes wood be of this species, and care and maintenance instructions are always provided for the installer and the homeowner to follow.
Mahogany is a heavy wood, and quite strong. Given these qualities, and that it has natural resistance to rot and decay, it makes an excellent choice for exterior doors.
Clear Pine is a soft wood, with moderate weight. During changes in humidity cycles, it is moderately stable with some expansion and contraction.
White Oak has a natural resistance to rot which makes it an excellent choice for exterior doors. It is a relatively stable with a bit more color consistency than Red Oak. It is also slightly heavier than Red Oak, and a bit harder and smoother. White Oak is a slow drying wood and stains well with a variety of finish tones.
Inspection of the exterior doors should be based on the installation, weather stripping and threshold installation, signs of planing for any previous adjustments, and verifying sealed bottom and tops of the doors.
Only water and moisture can cause a door to rot. Sealed and remove moisture contact, doors will last a long time.
I get the feeling that it might be poor maintenance of an exterior wood product.
Most high end doors in Maine last maybe due to storm doors on 75% of them.
Hope this helps.
Old 3/7/11, 4:53 PM
James E. Braun, CMI's Avatar
What is their definition of future; a few years or a 100 or so years?
Old 3/7/11, 6:41 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
John whatever you choose to do, please be careful and cover your butt 9 ways from Sunday. From the limited info you gave us, this sounds like some builder is going to get in a legal battle with a door manufacturer and or the installer. Just cover you back side.
Jim
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Old 3/9/11, 11:52 PM
jhugenroth jhugenroth is offline
Please Note: jhugenroth is a non-member guest and is in no way affiliated with InterNACHI or its members.
....and how many more doors you expect to rot in the future.
Get out the crystal ball. Be careful with this part! CYA with some additional PIA verbiage so they can't come back on you if you fail to predict the future correctly.
Level of detail in the InterNACHI Roof Inspection Certification course/ advanced desi kshepard Roofing Inspections 5 2/13/11 2:42 PM
Coming soon. Free, online, fireplace and chimney inspection course. gromicko General Inspection Discussion 15 12/14/09 4:19 PM
You guys are going to love this find belliott Inspection Education & Training 7 10/16/09 10:32 PM
QOD 04-14-06 Structural tgardner Inspection Question of the Day 4 4/17/06 8:06 PM
