Old 4/7/11, 12:43 PM
Patrick K. Breen Patrick K. Breen is offline
Default Hot Neutral Reversed Recommendations
What do you recommend?
I often find outlets that are Hot Neutral reversed. Sometimes GFCI's as well. The GFCI's function manually and power is disconnected. Testers though do not trip the circuit. Is it best practice to always recommend a licensed electrical contractor further evaluate and fix ALL Hot Neutral outlets, just GFCI's or what?
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/7/11, 1:12 PM
Vince Santos's Avatar
Vince Santos Vince Santos is online now
Default Re: Hot Neutral Reversed Recommendations
Never assume the buyer can fix anything electrical related. Always recommend repairs by a licensed electrical contractor on all improperly installed outlets.
BTW Edit your profile to include your location when you get a chance.
Vince Santos
StepByStep Home Services LC
(734) 748-9584
Providing Home Inspection Services to Southeast Michigan
facebook
ITA Trained and Certified
Old 4/7/11, 1:48 PM
Jeffrey R. Pope's Avatar
All improperly wired outlets need to be corrected. As Vince stated, always recommend correction (not evaluation) by a qualified electrician.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/8/11, 6:28 AM
Andrew Cox Andrew Cox is offline
That goes for any repair IMO, recommend a licensed contractor - it's up to the client who they use, but you've made the recommendation. If not, Harry Homeowner gets electrocuted and says, "But the inspector said I could re-wire this...!"
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Old 4/8/11, 6:57 PM
Brian E. Kelly's Avatar
That the condition be corrected by an Electrician.
Old 4/8/11, 8:54 PM
If he's been electrocuted he doesn't say anything--he just lies there.
Old 4/8/11, 10:09 PM
Lawrence W. Losciale's Avatar
Lawrence W. Losciale Lawrence W. Losciale is offline
If it's resent he might jerk around a bit.
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
THE "GROUNDING "TRUTH- Article To Read pabernathy Electrical Inspections 1 1/1/07 1:14 PM
Metal Rigid or PVC Rigid what is code bpotts Electrical Inspections 5 12/4/06 2:40 PM
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical Inspections 1 4/22/06 10:19 AM
