Not sure if this is acceptable. A smaller flex vent pipe going into a larger pipe and not sealed.
cbrands is a non-member guest and is in no way affiliated with InterNACHI or its members.
the smaller to larger is not in itself an issue.
the other way around would be. the fact that it is not sealed is wrong and DANGEROUS. call it out as a safety hazard and recommend repair. |
If the flex is continous to the exterior its ok. They may be using the larger pipe simply as a heat sheild to combustibles. Can't really for sure from those pictures.
If the flex is not continous then yes absoulutly it needs to be sealed. |
Even if you're not sure if this vent exits the building, simply recommend sealing vent at entry point of larger vent.
Common guys...look at the pic.
Yes it must be completely sealed. And if you look at the pic, the flex is angled down as it enters the hard line and with the gap......what's lighter than air....do ya smell that??????????? |
Is that dryer vent Pipe. This is very illegal in OH. The owners might be waking with headaches in the morning. Carbon Mon Detector is never there when you need it.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Definite safety issue. Also water heater appears to be a AO Smith late 80's early 90's. I would call out that as well.
Ray http://www.inspectorpages.com/rthoroman Home Inspection Gainesville, Georgia Home Inspector Atlanta, Georgia |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 9:36 AM |
| TPR & Combusiton Air | thejnicki | Plumbing Inspections | 16 | 9/18/06 8:55 PM |
| Picture of water heater vent pipe. | crichiii | Inspecting HVAC Systems | 1 | 9/1/06 12:14 PM |
