Does anyone ever test for humidity?
I know this is not part of the SOP but was just wondering. It would be nice to have for homes with a basement to see if there humidity levels were high. I have a gauge in my own home & keep my humidity between 35 to 45% By the way Professional Equipment has a 50% off sale on some nice items. http://www.professionalequipment.com...119-5050_m3150 |
Yes I take a relative humidity reading when warranted.
Spend the $$ and buy a good one. The cheaper ones aren't worth their weight and can give you false readings. |
When I get into a house I take a RH%, mostly for conversation and figure how sick I will be in a few hours. I did a home inspection where the house was rh 72%, had mold on walls, and mushrooms growing out of the carpet. Since the air was moist, the spores had to be thick. I felt like I chain smoked a pack of cigs when I was done.
tom |
$20.00, works fine. I do outside, home interior and basement/crawlspace. Outside provides a baseline, interior and crawl readings can alert you to moisture intrusion you can't see.
Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) EXPERT WITNESS Director of Green Building Director for International Development (303) 717-8940 (303) 258-8289 Last edited by kshepard; 10/2/08 at 2:38 AM.. |
Linas Dapkus Lockport,Il. 60441 #06012294 Chicago Home Inspector Chicago Home Inspection Chicago Home Inspector Linas Dapkus My Chicago Home Inspection Chicago Home Inspection Today |
I agree with Brian. There are way too many variables when determining a base line RH level.
Time of day is one huge factor. |
Oh, just some extra information. On the house that had a 70% RH, everything came up 'alarm' levels with my moisture meter. Having the RH helped me explain how I could not differentiate between the past like damage stains and an present water damage.
tom |
Outside humidity levels here seem to average between 25% and 40% but wood levels measured in log home exteriors are typically barely measureable with the surveymaster which has about 10% as the bottom of its range. Even with the conversion chart, wood moisture levels don't appear to mirror average realtive humidity. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) EXPERT WITNESS Director of Green Building Director for International Development (303) 717-8940 (303) 258-8289 |
| Roofing gauge | mcyr | Exterior | 13 | 7/4/09 2:01 AM |
| Moisture in slabs | mcyr | Structural | 7 | 8/20/07 8:33 PM |
| bbbb | mcyr | Structural | 1 | 8/19/07 11:26 PM |
| wire gauge / breaker rating | jweinberg | Electrical | 19 | 7/16/06 5:36 PM |
