Need this in electronic format (or scanned and e-mailed). Anyone got it?
Thanks, a ton!! I was told I have a big mouth. I objected and said it can't be, I can only get one foot in it. |
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey Scott,
Are you referring to a Uniform Building Code section? ICBO - International Conference of Building Officials was the publisher of the the various UBC Codes. Which have now been replaced by IRC Codes which are published by ICC - International Code Council. Try here: http://www.iccsafe.org/ Good Luck! |
It's in reference to the Hilti fastening 'goop'. Called "hilti hit HY-150". It's used for anchoring rebar in concrete for various purposes.
The Hilti HIT-HY chemical (epoxy) systems are about as good as it gets for fastening rebar or threaded steel into concrete.
What info are you looking for from the ICBO? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I do special inspections for an extremely large government job going on up here. I have done several so far for the Hilti fastening but now they want the ICBO quoted in the report (one page). I watched them unbox, load, prime, fill holes, and insert the rebar. Passed inspection when I saw them unbox the Hilti 'goop" and load it into the holes. I was told I have a big mouth. I objected and said it can't be, I can only get one foot in it. |
Is this what you need?
