Old 1/10/11, 6:26 PM
Jamie R. Wilks's Avatar
Jamie R. Wilks Jamie R. Wilks is online now
Default ice forming on roof via gas furnace vent
I inspected a newer home today and had the following concern.
The gas furnace and intake are located near the roof peak. The furnace was running and the vent/flue gases were exhausting or venting out of the plastic vent pipe. The problem was/is, the gases are condensing when they hit the cold air (20-30 degress, cold for Virginia), dripping down onto the roof surface, then forming ice. No leaking or ice formation was observed in the attic space. This does not seem correct. Has anyone else seen this condition? If so, what are your comments or concerns?
I noted the conditions observed, but I'm not sure if this can lead to problems. It just doesn't seem right.
Jamie R Wilks
North Star Home Inspections
VCHI #3380000351
InterNACHI #05081596
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/10/11, 6:46 PM
Roy D. Cooke, Sr's Avatar
Default Re: ice forming on roof via gas furnace vent
I'm am more concerned with inlet and exhaust being so close to one another .
I would pass this on ,Immediate ,further evaluation by qualified personal .
Old 1/10/11, 7:10 PM
Roy
the clearance between the inlet & exhaust/vent was noted, along with the ice and condensation.
Jamie R Wilks
VCHI #3380000351
Old 1/10/11, 8:02 PM
Wayne B. Wilson's Avatar
What Roy said
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 1/10/11, 8:21 PM
Banned
The supply and exhaust on the high efficiency, direct vent gas systems usually should be at least 12" apart but always check with the manufacturer's specs.
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
Gas furnace vent insulation Rick Vollmer Inspecting HVAC Systems 0 10/27/09 11:51 AM
2 hot water heaters and furnace on same vent sfalvey Inspecting HVAC Systems 17 5/2/08 11:38 AM
Is it possible to put in a ridge vent on a slate roof? Nathan W. Swilling Inspecting HVAC Systems 1 2/7/08 1:40 AM
