A plumber recently told me that water from the condensing furnace and AC units should not drain into a sump pump (mine does) it's required by almost all codes (according to him) to drain into a pit that is pumped by an ejector in the sewer or septic system. I've not written this up. Is it something you folks document ?
Bill Wieczorek Serving Northern Illinois Tri-County Home Inspection www.Tricountyhomeinspections.com |
Bill,
I looked through Illinois plumbing code real quick but didn't find anything. You might want to look through here and see that you can find. http://www.ilga.gov/commission/jcar/...0sections.html Jeffrey Wortham ANS Inspections, Inc. www.ansinspections.com 630.276.8440 638 Langford Drive Bolingbrook, IL 60440 NACHI ID:04050181 |
What would be the reason.?
Did he give you one. |
Something to do with chemicals by-products of the discharge. I don't know the specifics.
so Linas do you write this up?, and how dare you miss the meeting where all the report software blew up.
The plumber was full of it. Illinois has two plumbing codes. One for the state and one for Chicago (and some of the surrounding suburbs). The only difference is that Chicago does not allow supply piping other than metal (copper, preferably. who uses galvanized anymore? This is to ensure full employment by union plumbers. In Illinois, the unions control everything. Not by law, but by politics. You cannot sit for a plumbing license test, regardless of your expertise, without being a Union member. Once you get it, you can quit the union, but you have to re-license, sooner or later. Go figure Understand this, and you understand everything about the other big association. The answer to your question is no, the condensate can drain to the sump. Not "best practices", but acceptable, according to national standards. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Joe went to show off 3D and his software froze, then when I went to show HIP the top of my program was lost on the projection screen.From there my templates were scrwd up because I had just downloaded a update that caused a glitch.Talk about panic attack
Go's with being a Beta tester. At least I got to show how it downloads 5 photos a second. |
Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
We use to hang out at various watering institutions with Steve & Co. More than 27 years ago.. |
Then youse guys must remember the Coho lips, another kid in the crawl, and Steve Meirs Hat Dance, not to mention his Disco three blocks south.
Ah the good old days. I think I was going to the fish tank place around then. Can't recall the name , though it was over by the Limelight. |
I think I was there but I don't remember. Mark Jones Allmark Home Inspection Services Inc. Serving all of Northern Illinois, Vernon Hills, Libertyville, Gurnee, Fox Lake, Round Lake Phone: 847 651 2053 E-Mail: AllmarkInspect@aol.com www.AllmarkHomeInspection.com |
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 230 | 3/21/12 9:35 PM |
| Bungalows to Mansions Professional Home Inspection, LLC | bgraham | Miscellaneous Discussion for Inspectors | 7 | 1/11/09 3:03 PM |
| Liability question | jcahill | Legislation, Licensing & Legal Issues for Inspectors | 30 | 8/24/08 4:10 PM |
| Buckeye Home Inspections Service Area | sboyd2 | Miscellaneous Discussion for Inspectors | 3 | 9/4/06 7:21 PM |
| Buyers Best Home Inspections | ddinwoodie | Miscellaneous Discussion for Inspectors | 6 | 9/4/06 7:20 PM |
