Old 10/28/10, 10:22 AM
Darrell L. Freshour's Avatar
Darrell L. Freshour Darrell L. Freshour is offline
Default Increasing Water Pressure
I inspected a 6 yr old home in the rear of the new subdivision.
Water pressure was 30 psi.
Does anyone have any ideas to increase the water pressure ?
Darrell's Home Inspections
937-477-6917
http://www.darrellshomeinspections.com
Inspecting Dayton, Ohio
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/28/10, 11:39 AM
Joshua L. Frederick Joshua L. Frederick is online now
Default Re: Increasing Water Pressure
Municipal??
Old 10/28/10, 11:40 AM
John Harrison's Avatar
John Harrison John Harrison is offline
pressure pump
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas
Active Rain Member
http://search.aol.com/aol/search?que...nt91_searchbox
Yes sir
937-477-6917
Old 10/28/10, 12:20 PM
Jeff Zehnder Jeff Zehnder is offline
Many homes have a pressure reducing valve to regulate the pressure in the home since many municipalities are using high pressure to ensure all areas are serviced completely. If this home has one it should be located near the main shut off valve and is usually bell shaped. There is a lock nut and screw that regulate the valve. You can attach a pressure gauge on a hose bib and turn the valve until you are satisfied with the results. However, anything over 50 PSI is not a good idea and can lead to unplanned results.
J Jeff Zehnder
www.jjeffzehnder.com
Old 10/28/10, 1:52 PM
James E. Braun, CMI's Avatar
Thirty pounds would be an acceptable pressure to run a house on a well, so publisc water should be no different.
Old 10/28/10, 3:36 PM
Bob Elliott's Avatar
Also make sure the problem is not flow.
Are these galvanized pipes ?
90 PSI water pressure? dandersen Plumbing Inspections 32 7/12/10 9:42 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
