Old 6/27/07, 10:54 AM
Larry M. Martin Larry M. Martin is offline
Please Note: Larry M. Martin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Exclamation inspecting old homes
Hello all,
I am going to be inspecting a home that was built in the early 1900's. Are there any special concerns I should be aware of when inspecting a house this old? Any input would be greatly appreciated as I have never inspected a house this old.
Thanks,
Larry Martin
Mother Lode Home Inspections
Old 6/27/07, 10:57 AM
Default Re: inspecting old homes
Hey Nick!! Whats up?? Above thread says I am not a member...?? But I am....I am a member of NACHI
Old 6/27/07, 12:08 PM
Dennis R. Goudreau Dennis R. Goudreau is offline
there are concerns, In New England homes from this period usually had granite stone foundations which if not properly maintanied can leak pretty bad causing foundation movement and lots of repointing at a min, the sewer & drain line might be old cast iron, possible abestos on old boiler lines or exterior sideing, knob & tube wiring & on & on
Old 6/27/07, 12:15 PM
Jeffrey R. Jonas's Avatar
Larry...
Where is the home located?
Jeff
Old 6/27/07, 12:33 PM
Carl H. Lederhaus's Avatar
Carl H. Lederhaus Carl H. Lederhaus is offline
Watch for knob and tube wiring.
www.leaderhomeinspection.com
"Don't go where the path may lead you, go instead where there is no path and leave a trail"
Ralph Waldo Emerson
Old 6/27/07, 1:15 PM
lcapaul's Avatar
lcapaul lcapaul is offline
Please Note: lcapaul is a non-member guest and is in no way affiliated with InterNACHI or its members.
Especially in attics where insulation has been added and dangling wires in crawl spaces that may still be "hot". Wiring in general needs extra attention, in a hundred years many strange modifications may, and usually, hame been made.
Check the attic before walking the roof, I always do that anyway, but in some of those old homes you can much more eaisly step through some opening in the sheathing hidden by the roofing material.
Old houses can be a real pain, and take much more time generally than newer construction,........Charge More.
Old 6/27/07, 2:01 PM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
Larry:
Here's something that you might want to use.
This is an older home with sloping floors,wall/ceiling cracks, and some doors may not be square. These conditions are common in older homes. The extent and cause of these conditions are not within the scope of our inspection. The client may wish a further examination by a structural engineer.
hope this helps
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Old 6/29/07, 2:20 PM
Thanks for the info folks..By the way the house in on the west coast in the sierra foothills..
Learn the Differences: Site-Built, Modular, Manufactured/Mobile Homes jsieg General Inspection Discussion 10 12/22/07 11:20 PM
Toxic Gas in Mobile Homes jbushart Miscellaneous Discussion for Inspectors 0 11/12/07 8:31 PM
Grab Your Checkbooks - For sale: 2 million empty homes jburkeson1 Miscellaneous Discussion for Inspectors 2 10/26/07 7:22 PM
Wanted: Someone who can teach inspecting of manufactured/mobile homes. gromicko Miscellaneous Discussion for Inspectors 15 9/12/06 3:25 PM
